Thread: How do you remove.......
    Regular Member dudley6623's Avatar
    Sep 2009
    skegness lincolnshire
    Trim : SRI
    Engine : 2.0L Turbo
    Year : 04/54
    Mileage : 88000
    Default How do you remove.......
    Whats the best way to remove the blank plate on the dash so i can fit the TC switch, dont want to force it and break something
    thanks for the help
    Regular Member m300raj's Avatar
    Nov 2009
    Hampshire
    Use a small flat blade screwdriver to prise it out it will come out they can be quite a snug fit
    Dunstable
    Use a small flat blade screw driver and prise it out gently, go easy so you don't scratch anything.
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Bluetac
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    ...or a nice big blob of blue tack gets them off too
    Sep 2009
    Trim : SRI
    Engine : 2.0L Turbo
    Year : 04/54
    Mileage : 88000
    Thumbs up
    Thanks for the help guys
    East Midlands
    Stick some masking tape or any tape for that matter onto the end of a small screw driver,and gently prise towards you and it will pop out,and it should'nt get scratched using the tape...
    Chelmsford
    stick a bit of gaffer tape on and use it to pull the plug out...
  1. How do i remove...
    By OllyT in forum Styling
    Last Post: 12th December 2011, 15:08
  2. How To Remove.
    Last Post: 6th July 2011, 09:10
  3. can i remove them?
    By vectra_c_wannabe in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2010, 19:42
  4. Best way to remove hub nut?
    Last Post: 18th August 2009, 23:11
  5. How do you remove
    By Triple Trouble in forum Engine & Drivetrain
    Last Post: 31st March 2008, 19:11
