Thread: fault codes
    Regular Member dan1983's Avatar
    North London
    Default fault codes
    Hi all, i had my 2 lambda sensors changed due to the emissions light coming on and mechanic plugged it in and it came back with o2 sensor fault. do i now need to clear the faults or will they clear automatically.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Plugged it in?
    Plugged what in and where? If he has a codes reader then he should have also been able to reset.
    If you leave battery disconnected for 1/2 hour it may do it, or if the fault goes away (new sensors fitted) it may equally reset itself. I don't know for sure, as I've not had to change an O2 sensor before.
    North London
    He had a code reader, but i did the work myself and dont want to be charged again to have it plugged in
    Jul 2009
    The Rift, Cardiff
    I've had similar on my 1.8sxi, came up as 'oxygen sensor bank 1'. Had both changed but same code came up again, more money spent - another problem not solved. I'll give the EGR a clean out next, if that dont work i've been told to try the MAF.
    As Ste said disconnect the battery for half hour then take it for a drive and see if eml comes on again (dont forget you'll need the radio code)
  1. fault codes?
    By farley2708 in forum Engine & Drivetrain
    Last Post: 5th February 2012, 00:18
  2. fault codes
    By ADAM123 in forum Engine & Drivetrain
    Last Post: 31st January 2012, 19:02
  3. Fault Codes
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 10th November 2010, 09:49
  4. Fault Codes
    By cdms811 in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2007, 14:17
