Results 1 to 2 of 2
Thread: Lambda change
    Midlands
    Thumbs up Lambda change
    Hi
    If I change the sensor because of a fault, Will the fault light go out on it`s own or will I need to get it turned off?
    Worcs/Staffs/Westmids (ish)
    I think you'll have to get the ECU reset, most cars require this once a fault has been detected. Some you can simply disconnect the battery over night, others require more complex procedures.
    It's probably not relavent, but a fault normally has to be detected 3-5 times within a time frame for the ECU to register it as genuine fault, you'd be suprised how many false calls an ECU can pick up during its life.
    Your lambda could have been intermittently faulty months before the ECU detected it.
  1. EML 2.0T Lambda or CAT
    By a1ant in forum Vectra C / Signum Troubleshooting
    Last Post: 20th August 2011, 20:53
  2. Cat Or Lambda
    By Tam80 in forum Vectra C / Signum Car Chat
    Last Post: 6th July 2011, 21:03
  3. Lambda help
    By Barnes in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2010, 20:42
  4. lambda sensor again!
    By deg in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2009, 23:49
  5. Lambda
    By VECTRAMAN in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 10:33
