Thread: Any Advice
    Nov 2009
    tredegar
    Default Any Advice
    Hi guys, I know this is a vec c forum but i have a problem with my vec b its a 2.5 v6 and when the weather is very cold as it is now when i start her she will rev from 1000 to 2000 continuously for ages or untill i get a good speed up on the road i hope you can help as its doing my head in cheers in advance markf
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    i changed the air flow meter on mine when it started playing up if i remember rightly. hth
    May 2008
    Tyneside
    Could be the idle speed stepper motor sticking, happened on my vec B 1.8l. Try removing and cleaning it with carb cleaner. HTH
    Worcs/Staffs/Westmids (ish)
    Quote Originally Posted by tridley View Post
    Oddly enough WD40 is an excellent carb cleaner, especially if your rebuilding a pair of webbers
    In fact short of destroying bicycle chains (by removing the pre installed, it's probably the only real use it has
    Nov 2009
    tredegar
    well thanks guys took off offending idle speed valve, and soaked it in various solutions and potions, but i broke the bleeping gaskit so after a hastily made one from paper and a call to the vauxhall stealers to price a new gaskit..... the price was so reasonable i ordered 2 they were £0.72 each. so its back on and fingers crossed touch wood it seems to be ok forgot to say i asked the parts advisor in vauxhall the price of said idle speed valve drum roll please £218
    Wales, UK
    Quote Originally Posted by markf09 View Post
    Yep another fault but an easily fixed one. £218 is rediculous !!
    Glad its ok mate, I miss my 2.5
    May 2008
    Tyneside
    I got a idle speed stepper motor from Autovaux was only £45 (a few years ago) and it was a genuine siemens unit. There was a modified stepper motor produced, the siemens number on the end was suffixed with a 'X'.
  1. ebay advice , think someone is trying it on , need advice ...
    By poves in forum General Motoring Chat
    Last Post: 22nd August 2012, 00:29
  2. Need help and advice please
    By Angel1368 in forum Engine & Drivetrain
    Last Post: 9th June 2012, 11:19
  3. Need advice what would you do....
    By pipamish in forum General Motoring Chat
    Last Post: 2nd December 2011, 02:13
  4. Newbe after advice, lots of advice!
    By rb199 in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2011, 19:08
  5. Advice please?
    By RN37 VXL in forum Engine & Drivetrain
    Last Post: 16th October 2009, 17:59
