Results 1 to 10 of 11
Thread: Z19dth EGR failed again!!
    Default Z19dth EGR failed again!!
    Just had my service done and on the way there the exhaust emissions light came on (little picture of an engine in the bottom right of the console). Vx tell me its the EGR valve again (only replaced under warranty 18 months ago) and they want £260 to fit a new one for me.
    My tame mechanic has offered to take it out and clean it for a lot less than that, and I'm going to give it a go before having to put an EGR in it (still for a lot less than Vx quoted).
    My question is...... will the light on the dash reset itself after the fault is sorted, or will I need it tech 2'd? ..... if so...... does anyone in the midlands got a tech2?!!!!
    May 2007
    Norway
    Just to ask the obvious..... Your car has been updated to not show a light when it is doing the DPF-cleaning process?
    If related to EGR, the error-code will probably have to be cleared out by either a Tech-2 or other faultcode-reader/reset device.
    It is a hatchback, so no DPF.
    Anyone know for definite?
    Bristol
    Vehicle : CDTI 150
    If it is the EGR, they cost £106 including gaskets, new delivered to your door.
    Replacement takes about 20 mins just need a small flat bladed screwdriver a 10mm and 13mm socket.
    Replacing the EGR is fine (still not done it!!), but will I need Tech2 to cancel the light on the dash?!
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    put the modified valve on she'll be fine
    Regular Member Dose's Avatar
    Falkirk/dunfermline/alloa
    Quote Originally Posted by Jamie View Post
    no mate any fault code reader will be fine to reset the light.
    Admin plasma's Avatar
    On the Forum
    187 Post(s)
    Engine : 150
    Mileage : 74000
    If its the emissions light thats staying on then a battery disconnect should clear it
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    The emmissions light may go out itself providing the cause of the fault has been sorted. £260 for the EGR valve?? Stupid money it cost about £120 from the dealer and takes next to no time to fit with a decent socket set.
    Insignia VX-Line Nav CDTI 170.
    N.Ireland
    My emissions light went off the last time if I remember well...As for the price they're looking for fitting the EGR,don't even think of it,daylight robbery that ,you could get the ferry over here for that price and I'll fit it in 20 mins.
  1. Z19dth DMF
    By neill in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2012, 15:30
  2. Oil for z19dth
    By neill in forum Engine & Drivetrain
    Last Post: 18th July 2011, 18:45
  3. z19dth
    Last Post: 22nd April 2011, 08:38
  4. Z19DTH - Which Oil?
    By treadstone in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2011, 17:22
  5. z19dth
    By taralko in forum Troubleshooting
    Last Post: 1st July 2006, 13:36
