Thread: Why can't Vectra's be this cheap!
    Regular Member wotsthestory's Avatar
    Jun 2007
    Carshalton
    Engine : 3.0 CDTI
    Mileage : 103000
    Smile Why can't Vectra's be this cheap!
    I've got this P reg cheapy run about Corsa, for whilst I was finding my Vec.
    Discovered the 'stat was knackered (not good right now). Thought I'd replace that, easy job.
    It's a 1.4, the 'stat is actually behind the cambelt cover, so drive belt, cambelt and cover need to come off. Even though it's a cheapy, I thought I'd price up the bits to do it properly, rather than remove replace existing.
    Cambelt > £7
    DriveBelt > £3
    Stat > £4 (including gasket)
    WaterPump > £14
    RockerCoverGasket (weeping slightly) > £2
    All from EuroCarParts!
    Can't wait to get stuck in now and do it.
    Regular Member PORKBALLS29's Avatar
    Epping
    Well done Brian keep up the good work.
    Regular Member Gregg's Avatar
    Aug 2007
    Great Wyrley
    bear in mind that the corsa was 92/93 when it was first built so its going to be very simple stuff.
    Newer cars everything seems to be expensive
    Mar 2007
    North East
    The mechanic who looks after the wife's corsa, had a real fight when he changed the cam belt, apparently there is not alot of room with a 1.6 lump under the bonnet.
    Jun 2007
    Carshalton
    Engine : 3.0 CDTI
    Mileage : 103000
    I took the airbox off this thing and could practically stand in the gap.
    Regular Member danBoy's Avatar
    Jun 2006
    Northampton
    I may need to do the stat on my old gay Corsa as the heating doesn't feel as warm as it should be but far too stingy to spend on it yet
  1. Cheap upper control arms? Buy cheap, buy twice?
    Last Post: 12th October 2012, 11:26
  2. cheap vectra's......
    By david.aka.judas in forum Vectra C / Signum Car Chat
    Last Post: 16th May 2009, 21:51
