Thread: Radiator Leaking! Help!
    Chelmsford
    Default Radiator Leaking! Help!
    Hi guys,
    following my earlier threads about disappearing coolant, I've had the bonnet up today to find the expansion bottle completely empty... Closer inspection reveals a nice drip from the radiator and a pool under the car...
    Bit of a relief, as I'd started worrying about head gaskets etc...
    The drip is coming from corner of the radiator, offside, just in front of and below the air con. Looking from the top I couldn't see any pipes from that section of the rad, going to jack it up in a minute and take a proper look. Any idea what there is on the bottom, left hand corner of the radiator on a 2004 1.8 petrol?
    The system is full of antifreeze, as demonstrated by the large puddle of yellow on the drive where snow used to be! Oddly, the car has been left overnight, but the drip is quite continuous now, 14 hours later. I have no idea what could have caused it to get worse in the past hour or so.
    Any ideas for me? Thanks guys.
    Edinburgh
    Could be a loose or cracked hose, or could be radiator has corroded and is leaking I guess. Closer inspection would seem like best bet.
    Full Member spennny's Avatar
    Blantyre
    Off side, Isnt that where the plug is to empty the rad when changing coolant, looking at the car its bottom left of there, maybe this has dislodged , worth a check,
    Jul 2009
    The Rift, Cardiff
    Mine was rusted/corroded all along where metal meets the plastic side parts. A new rad was around £150 fitted (70ish part). I wish i'd done it my self tho as the garage fudged my immobiliser and cost me another £120.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    If the leak isn't too serious a can of Red weld (or other) may be OK.
    Chelmsford
    Mine is corroded along the offside edge... Extreme cold must have split the weakened metal.
    Just bought the new part online for £60. Would fit myself but it's too ****** cold! Garage are doing it on Wednesday...
    Jun 2007
    Black Country
    A tube of JB weld would have been a much better idea, costs £5 and sticks to anything, Ive rebuilt engine casings with this stuff
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Probably, now we know it is more than just a slight leak.
    Chelmsford
    i would use rad-weld if i absolutely had to use the car, but i don't for the time being so going to get the job sorted properly.
    Besides, I've see a fair few posts on here with people having the exact same problem, so even if i did a temp fix it would undoubtably get worse anyway.
  1. Leaking Radiator
    By neocaligatio in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd June 2012, 13:58
  2. leaking radiator
    By coooky in forum Engine & Drivetrain
    Last Post: 8th November 2011, 10:58
  3. radiator leaking
    By recoveryman in forum Vectra C / Signum Car Chat
    Last Post: 29th May 2011, 16:42
  4. Radiator leaking
    By Swatty in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2010, 15:53
  5. Radiator leaking from drain tap
    By fuzzbomUK in forum Engine & Drivetrain
    Last Post: 30th March 2009, 19:53
