Thread: Alloy wheel question
    Regular Member SRIRob's Avatar
    Jan 2010
    Essex
    Default Alloy wheel question
    Got 17s on my veccy but just read a post on here about wobble bolts and being able to fit different wheels
    On my Volvo V70 I just sold it had a set of MAK 18s fitted with 235/40/18 the stud pattern is 5X108 the cnte bore is the same 65.1 same offset 35-34
    so all the same apart from the stud pattern which can be sorted with the wobble bolts
    Question will the trye size be ok 235/40/18 (no rubbing) and do you guys think they would look ok on the Veccy from the pic below
    Cheers Guys
    Jan 2010
    Essex
    Forgot the piccie OOPS
    Regular Member keith1983's Avatar
    Sheffield / Spalding
    Vehicle : Vectra 1.8 SRi
    Engine : Z18XE
    I think they would suit the veccy down to the ground, as for rubbing you shouldn't have any problems. Are you running standard shocks and springs?
    Regular Member P3tchy's Avatar
    Milton Keynes
    Should go straight on with some wobble bolts.
    Full Member Lao's Avatar
    Aug 2009
    Romania, E.U.
    Vehicle : Vectra C Estate Automatic
    Trim : Elegance
    You can input all info you have on the wheels and tyres into this: http://www.rims-n-tires.com/rt_specs.jsp
    At the lower part you have a conclusion.
  1. Alloy wheel question
    By djr69uk in forum Styling
    Last Post: 14th August 2011, 21:27
  2. an alloy wheel question
    By pogo in forum Suspension, Wheels & Brakes
    Last Post: 15th March 2011, 21:22
  3. Vectra C Alloy wheel question
    By MarkC in forum Suspension, Wheels & Brakes
    Last Post: 21st May 2007, 12:23
  4. Alloy wheel refurb question
    By Madgunner in forum Vectra C / Signum Car Chat
    Last Post: 11th April 2007, 09:42
