Thread: Battery Lilght and no climate control
    Regular Member Blagmeister's Avatar
    Warks
    Default Battery Lilght and no climate control
    Got a problem on the electrical system this time....
    Coming home the other night amongst all the snow and cold and the battery light on the dash came on. SWitched everything off just in case the alternator had let go and got home ok. Came to go to work this morning and it started ok but no climate control/heater/fan and no rear demist. After a couple of mins the battery light came on again...
    Any ideas?
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    same thing happened to me but not with the heater car runs fine then after about 5mins of driving battery light comes on, if you turn off car its fine for another 5 mins then i lost all power and electrics as the alternator gave up
    check the voltage with a multimeter when the engine is runnign should read about 14 volts ish
    if alternator is f***ed about 12 or even lower hope this helps
    Warks
    Thanks for that. I suspected as much and its going in tomorrow [again!] to get it looked at. New alternator is around £300 fitted. :S Just what I need right after Xmas!
    kings lynn, norfolk
    im just glad my car is still under warranty as its at the garage now getting new flywheel and clutch, inlet manifold, thermostat, and alternator
    there must be some big faulty components in vectras.
    do the fiats and alfas have as much trouble as our vectras
    Apr 2008
    Belfast
    Same thing happened to mine today! Got RAC out, alternator away! Bad times!
    King's Lynn
    I had an alternator go as well. Don't try to drive to far with the light on as the electrics work all sorts, The power steering, abs etc. The radio was a good indicator prior to total shut down..
    Regular Member Driver0069's Avatar
    Oct 2009
    South Yorkshire
    Eek
    Same thing happened to me my battery light came on friday took it to the garage and guess what alternator gone i think what else could go wrong ?
  1. Climate control help
    By neill in forum Engine & Drivetrain
    Last Post: 3rd December 2011, 18:37
  2. Climate control and GID
    By Ben_ in forum Electrical & ICE (including SatNav)
    Last Post: 5th October 2011, 19:30
  3. climate control
    By stu_c in forum Bodywork & Interior
    Last Post: 5th January 2011, 12:34
  4. climate control
    By stu_c in forum Vectra C / Signum Car Chat
    Last Post: 13th December 2010, 18:27
  5. Climate control Help
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2009, 00:23
