Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: 1.9cdti 150 thermostat replacement
    SAUCHIE
    Default 1.9cdti 150 thermostat replacement
    Hi all.
    Has anyone changed a thermostat on a 1.9cdti 150 and if so how difficult was it? I am getting a thermostat from the stealers tomorrow and going to replace it. I did the one on my 1.8 petrol and it was a breeze. Is the 1.9 any different?
    Many Thanks
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    not that hard the thermostat is on the right hand side of the engine take off the air pipe on the right and its on the side of the block with the radiator hose coming off it and a electrical connector which is the temp sensor. you will have to bleed the coolant system once you have chaged it but if needed you might aswell replqace your full coolant if needed. hope this helps its not that difficult just a few general tools is needed.
    hope this helps
    Feb 2007
    Leicestershire
    Changed mine on a 120 1.9 cdti on a Signum. What a b**ch to do. Remove the battery to get access. Then try to remove the heat exchanger. VX say its held on by 2 bolts!!!!
    What about the third one at the back that you can't see?
    Any no its fitted the temp gauge shows 84-86 after about 5 miles, and the fuel consumption on me 26 mile trip to work has risen from 43 to 51 mpg.
    Sep 2009
    St Albans Herts
    Smile
    did mine a few weeks back, did not loose much coolant needed about 2 litres, (bought pink stuff from vx) did not need to disconnect or remove battery. came with a paper gasket but not needed as thermo has "o" ring. did not take long and has had a marked difference to car. I knew nothing about needing to blled system and mine was fine but when I read somewhre else it whould be done I did it but think I didn't really need to as no air came out. bleed valve is on shiny pipe at front of engine small black thing.
    16v's are much easier than 8v's
    as my coolant was shiny and pink did not feel need to change it so just topped up what was lost
    Bridgwater
    I'll be doing mine the weekend so I'll keep you all posted.
    kings lynn, norfolk
    what is the normal operating temp for the 1.9 cdti 150 and how long roughly does it take to reach it thanks
    May 2007
    Norway
    Did mine a few weeks ago, as Veralum said pretty straight forward and approx 2l of coolant to refill afterwards. -Bleedeing is essential, otherwise no heat inside the car. (That is wat happend to me.....)
    I removed the battery and plastic-case for battery. Only 2 bolts connects the thermostat to the engine, but the hanger for the lower plastic coolant-pipe makes removal and refit a bit of pain. (Z19dth engine)
    Normal engine temp is 85-88 after new thermostat, 5-10 minutes to warm up if normal driving.
    SAUCHIE
    Thanks guys.
    Changed thermostat yesterday and all went well. I didn't need to remove battery just airpipe and a rather large silver control box and then remove pipes and remove thermostat. I replaced it with a genuine VX one and replaced the lost water with 2 litres of anti-freeze (the VX stuff ) and bleed the system. Sadly no gain was had. It still takes ages to heat up and when I put heaters on full it slowly brings water temp down to cold and heater then becomes poor and will only heat up when I turn heater off. MPG crap 37 MPG. Only had car about month but can't see me keeping it to long with this really poor MPG. Contacted VX who are not interested 1 little bit. ******s !!!
    Sep 2009
    St Albans Herts
    Quote Originally Posted by winnie2457 View Post
    mine seems to run at 85 in this weather , seems to takes ages to get there compared with my 2.2 petrol omega, but diesels have heavier engines so think this is normal, heater is hot long before gauge moves
    Sep 2009
    St Albans Herts
    my drive slopes downwards which is probaly why i got away without bleeding system
  1. Thermostat Replacement - Any Tips?
    By Jezzy in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2014, 23:30
  2. Thermostat Replacement
    By dexter69 in forum West Scotland RO - Mr Gee, ARO - RBH
    Last Post: 18th May 2012, 18:59
  3. Thermostat replacement
    By ChrisB in forum Engine & Drivetrain
    Last Post: 21st November 2011, 13:40
  4. thermostat replacement
    By duncmill in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2010, 21:25
  5. vectra 1.9 120 thermostat replacement
    By tom_nw in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd December 2010, 14:41
https:www.vectra-c.comforumshowthread.php99200-1-9cdti-150-thermostat-replacement
vectra c thermostat
vectra c thermostat replacement
vectra c thermostat change
how to change a thermostat on a vauxhall vectra cdti
vectra c 1.9 cdti thermostat replacement
vauxhall vectra thermostat location
vectra cdti thermostat change
thermostat for vectra 1.9 cdti
how to change thermostat on vauxhall vectra c
vectra cdti thermostat removal1.9 cdti thermostatchange thermostat vectra 1.9 cdtivectra thermostat replacementthermostat vauxhall vectra 1.9 cdtivectra c thermostat 1.9 cdtivectra c 1.9 cdti 120 thermostatvauxhall vectra 1.9 cdti sri 150 thermostathow to replace thermostat on vectra cfit vectra thermostatvectra c 1.9 cdti thermostathow to change temperature gauge on water system on Vauxhall Vectrathermostatic valve vauxhall vectra c replacehow to change thermostat vectra cchanging thermostat on vectra c
