Results 1 to 10 of 11
Thread: engine idle on the 150 cdti
    Regular Member rozzer2006's Avatar
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Engine : 2.8 v6 Turbo
    Mileage : 69k
    Default engine idle on the 150 cdti
    my car has started to idle as if its about to cut out then gose back to normal, happens sometimes when i'm slowing down for lights or something and i put it into netral or the clutch in. spoke to my remap man but he said it was a vx problem not his remap, its going in for a service on the 16th so i'll get them to look at it just if any of you knew what it might be?
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    swirl bar,egr valve,boost sensor, check these + clean, all can be found in the how 2's.
    Sep 2009
    GLASGOW
    Hi rozzer please let me know how u get on mate , mine startin the same probs
    Aug 2009
    Havant
    egr valve refurb howto isn't on the howto index as far as i can see... you can find it here:
    http://www.vectra-c.com/forum/showthread.php?t=45867
    Regular Member OSSY's Avatar
    Apr 2009
    Hi mate,
    I had similer issues just before my manifold died on me. I'd most def check all of the above EGR valve etc...
    http://www.vectra-c.com/forum/showthread.php?t=96227
    The above link is a brief account of how happy I was when I changed my manifold. However, you need to get to the bottom of the issue before speculating on such things as a new manifold. It could just need an internal clean - a good old flush out.
    Hope you get things sorted...
    Apr 2009
    Also - see the below thread. It has a pic in it of my old manifold, if you have any play at the top of any of the valves, you may have an issue with the manifold. What I mean by that is (not to sound patronising) if you can pull at the top of any valve, so it moves up and back down again, even a few mil, the chances are that you valves are dieing.
    BUT - this is only what I know...
    http://www.vectra-c.com/forum/showth...highlight=OSSY
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Quote Originally Posted by OSSY View Post
    Erm dude - thats my manifold as its my pic
    Apr 2009
    Sorry Ant, I've taken so may pics of my old one and cut and pasted so many from tinternt - I got my pics mixed up.
    However, lets not hijack this guys thread with our chit chat...
    Middlesex
    Trim : SRI
    Mileage : 100k
    no worries fella - just muckin.. as long as the pics all help..
    On topic - agree it certainly could be the inlet and suggest checking that the bar hasnt fallen off...
    Note: it falls off as the ball joints wear due to excessive up and down movements of the swirl flaps themselves, causing the gum up of the valves. This excessive up and down movement is due to wear on the bearings.. the new inlet is supposed to address these two wear areas.
    Another possible cause is the injectors.. I needed a set of 4 due to iratic idle - once replaced the car was amazingly smooth.. (this was after the inlet was replaced after the rod fell off too)
    Tech2 can test the injectors i believe for flow and functionallity.
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Mileage : 69k
    well its under warranty lol so all get them to fix it its going in for a service on the 16th .
  1. Engine won't idle! Help!
    Last Post: 5th December 2010, 17:43
  2. engine drops below idle??1.9 cdti 150
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 14th November 2010, 00:48
  3. engine on idle
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 23rd November 2009, 12:33
  4. Replies: 4
    Last Post: 31st July 2008, 15:29
  5. Engine Timing/Idle
    By Andy17899 in forum Vectra C / Signum Car Chat
    Last Post: 8th October 2007, 17:49
