Results 1 to 10 of 19
Thread: rubbing noise/droning ?
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Default rubbing noise/droning ?
    Replaced 2 tyres today cheers Glen put them on the back
    All though the droning noise isnt as bad as what it was it seems i have either a rubbing noise or droning from the front but un like most this gets louder when i slow down so not sure if its bearings.
    Its a bit hard to tell you's what the noise is but as i slow down it seems to slow the noise down until i stop,it does it whether i dip clutch or slow down without touching brakes,at first i thought it was something to do with maybe my brakes but even without touching them and just easing off throttle to slow down it still does it ,and same if i stomp hard on brakes
    it sounds like this
    ERRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRStop
    Dont laugh lol
    Any idea's didn't do it before i changed wheel's could it be the droning from the fronts i haven't changed ? just a bit weird how its more noticeable at lower speeds
    Irmscher Insignia CDTI 130
    Sunny Dartmoor
    I think it couldn't be your bearings or anything else,must be the tyres m8.
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Hope so its just too cold to do any thing i might try and jack up front tomorrow and if i cant see anything i'll stick 2 of my sri wheels back on and take it for a test drive
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Don, it must be the tyres mate if it was the wheel bearings the noise would be worse as you turn and more of a arharharharh rahter than ererererere lol Change the backs to the front and fronts to the back also check that they are not directional tyres and been put on the wrong wheel and are therefore running backwards.
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    1st thing i checked was directional think best bet is to change fronts over to my sri wheels then take it for a spin hopefully noise will go so i can rule out bearing or even gearbox
    WGAF#5
    Don its not a build up of surface corrosion on the discs??
    with all of the salt and moisture at the moment they will start to corrode in hours rather than days and then your not using the full efficiency of the brakes owing to the icy snowy conditions so the inner surfaces are probably scabbed and could be the pad just rubbing on the inner surface of the disc - jack up the front and spin each wheel - see if you can hear the noise that way and if the wheel also doenst spin freely could also point to the brakes/discs - will save you having to change wheels - if this doesnt work then at least you can swap tires after
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    I did think thats what is sounded like you know when your pads get low and start grinding a bit,sounds like its crabbing if you know what i mean
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    ** UPDATE **
    Didn't have a trolley jack today so done my best with the little scissor jack
    No play in wheels up or down either side but when i spin wheel (as best as i can )
    there is a grinding noise that come's and goes as you spin it sounds like its coming from callipers or there about.Checked tyres and if you run hands up them there are ridges on the edge that catch but in centre it doesn't.
    Now the noise is on both side's so i assume its not a wheel bearing coz my noise gets louder as i slow down plus if it was a wheel bearing when i spin the wheel wouldn't it be there for a full turn,plus no play up or down.
    I did wash car and jet wash wheels just before the big freeze and it didn't move for a a day and a half after it.So im a bit lost as noise is louder as i slow down
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Just a quickie should there be any play from front wheels in the 9 to 3 oclock position ? so if wheel is jacked up grab it on left and right and move it back and fourth
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    i'm getting a noise since changing wheels. i think its a wheel brg
  1. Rubbing noise nsr
    By pipamish in forum Suspension, Wheels & Brakes
    Last Post: 27th December 2011, 01:05
  2. drumming/droning noise
    By paulb70 in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2011, 15:31
  3. Droning noise
    By HHH in forum Engine & Drivetrain
    Last Post: 18th June 2010, 20:36
  4. droning noise when reversing
    By Morephun in forum Suspension, Wheels & Brakes
    Last Post: 16th March 2009, 08:52
  5. rubbing noise?
    By Messenger in forum Engine & Drivetrain
    Last Post: 24th February 2009, 21:21
has anyone had a problem with there inner cv joint on there insignia
vectra c inner cv boot noise
