Thread: Dosent start? Vectra C 1.8 2005mod
    norway
    Vehicle : vectra c
    Engine : 1.9 cdti (120)
    Default Dosent start? Vectra C 1.8 2005mod
    hi im from norway and i have a Opel Vectra C 1.8 (stationwagon, petrol) Z18XE
    it hapent ca 20 des i went to pick up my nabor at a bar. it started right up as useal no problem, i drow ca 15 km and turned of the car.
    ween i came back the car started and died right away ca 1 sec ... i tryed a cupel of times , agen it started up and died right away. un til the battery was flat.
    Next day i change the batery for a new one. and the engin turns ower butt it dosent start.
    i had a mate of mine (from opelmotorsport.com) come ower with his laptop to read the fault codes. (as shown in the botom)(just ignore the light bulps ,ant geting new ones untill the car fires up.and dorknob is working fine and brakes are ok just the vire to the sender thats caputski)
    we have tested most fuses (p15 isent there and hasent bee for som time it seems.
    wondering about the reles butt tryed the knokking metud with out any result.
    and it seems the fule pump dosen get djuse to the fuse (mekanik friend that tested...)wondering if i shud macgyver test it?
    im wondering it the ecu is gone but everything seems ok?
    (some stolen questions)
    Is there a spanner light on : No
    Is it turning over : yes
    Is battery dead : No
    Is starter motor turning or is it clicking : turning
    Are you parked facing up a hill : No
    Have you got petrol : Yes
    DIAGNOSTIC REPORT:
    OP-COM 090714
    Autosale
    **********************ECU ID STARTS**********************
    Source Address: ECM
    Source Address: 0x000007E0
    Identifier: 0x0206
    System name: Z18XE
    VIN: W0L0ZCF3551020091
    Hardware number:2001000
    Part Number:55557540
    Software version number: 6577915106
    System description: SIEM 0100
    Type approval number: S05009
    Alpha code:
    Number of stored fault codes: 3
    P1525 - Throttle Control Malfunction
    (65) - Not present
    P1550 - Electronic Throttle Control Engine Stop
    (3A) - Not present
    P1526 - Throttle Control Malfunction
    (61) - Not present
    **********************ECU ID ENDS**********************
    Source Address: ABS/TC/ESP
    Source Address: 0x00000243
    Identifier: 0x0301
    Hardware number:12801327
    Part Number:13136694
    Software version number: 00C3552E
    System name: ESP EBC430
    System description: TRW 0300
    Alpha code: EZ
    Number of stored fault codes: 1
    U2142 - CAN-Bus No Communication with YRS (Yaw Rate Sensor)
    (00) - Present
    Source Address: EHPS
    Source Address: 0x00000244
    Identifier: 0x0104
    Hardware number:24444336
    Part Number:0
    Software version number: V20_
    System name: EHPS GEN3 TRW
    Alpha code:
    C1550 - Replace Electronic Control Unit (ECU)
    (37) - Not present
    Source Address: REC
    Source Address: 0x00000254
    Identifier: 0x0104
    Part Number:13189924
    Software version number: 00000BBD
    System name: REC
    System description: LEAR 0400
    Alpha code: EU
    Number of stored fault codes: 2
    B3881 - Rear Left Tail Light Circuit Open
    (04) - Present
    B3883 - Rear Licence Plate Lights Circuit Open
    (04) - Present
    Source Address: UEC
    Source Address: 0x00000253
    Identifier: 0x0104
    Part Number:13187504
    Software version number: 00000BBC
    System name: UEC
    Alpha code: EH
    B2585 - Front Left Parking Lamp Circuit Open
    (04) - Present
    Source Address: DDM
    Source Address: 0x00000259
    Identifier: 0x0301
    Part Number:13170178
    Software version number: OP1D 190000
    System description: SIEM 0401
    Alpha code: EL
    Manufacturing date: 038040
    B2966 - Driver Doorknob Circuit Open or High Voltage
    (05) - Present
    norway
    Vehicle : vectra c
    we just took a new fault code reading... only some lights , brakes and door knob.
    engine turns over .. just dosent start... fuse to the pump dosent seem to get any djuse..?
    here are some photos of my ecu
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Try the manual way of retrieving fault codes too
    http://www.vectra-c.com/forum/showthread.php?t=81742
    It will only show up relevant codes.
    Are the relays clicking when you turn ignition on? Has a master fuse blown? These are the big ones in the engine bay fuse box
    norway
    Vehicle : vectra c
    im going there now to sweere and curse at the car now.. ill check it ones again
    VIP-Member sulten's Avatar
    Øvre Årdal, Norway
    9 Post(s)
    So you still are in trouble.
    Have you and fikse tryed the Blomdal ECU yet?
    Kristian
    68 Diplomat-A 46S
    95 Vectra-A C20NE
    07 Vectra-C Z19DTH
    norway
    Vehicle : vectra c
    jebb still still in truble... its going to the opel dealer now.... the tow trucks on its way now :/
  1. Car Won't Start!! - Vectra-C
    By coombesd in forum Engine & Drivetrain
    Last Post: 19th May 2011, 20:09
  2. Vectra SRI won't start / cuts out
    By mittu1 in forum Vectra C / Signum Troubleshooting
    Last Post: 15th March 2011, 21:38
  3. Please HELP - Car Won't Start (Vectra C)
    By d-suhiti91 in forum Vectra C / Signum Car Chat
    Last Post: 1st March 2010, 09:12
  4. Vectra 2.0 cdx won’t start?
    By PapaTgash in forum Vectra C / Signum Troubleshooting
    Last Post: 4th December 2007, 09:06
vectra c abs fuse blown engine doesnt
