Thread: Bulb Guide!
    Regular Member maurauth's Avatar
    Southampton (Locks Heath)
    Default Bulb Guide!
    I thought as it's such a pain the arse searching through the handbook and forum posts to find out what bulbs go where in your Vectra / Signum that I'd write a guide to all of them. Hope this is spot on I think it is, would anyone be able to check it over before I submit it has a How2?
    How2: Identify what bulbs you need!
    Pre-facelift Vectra
    Dipped Beam: H7 (477)
    Main Beam: H7 (477)
    Sidelights: W5W (501)
    Front Indicators: PY21W (581)
    Front Fog Light: H3 (453)
    Side Indicators: W5W (501)
    Rear Indicators: PY21W (581)
    Rear Side Brake Lights: P21W (382)
    Rear Centre Brake Lights: Seperate Unit
    Tail Lights: P21W (382)
    Reverse Lights: P21W (382)
    Rear Fog Light: P21W (382)
    Number Plate Bulb: W5W (501)
    Front Courtesy Lights: W5W (501)
    Rear Courtesy Lights: W5W (501)
    Glove Box: Festoon 42mm
    Facelift Vectra
    Main Beam: H1 (448)
    Rear Side Brake Lights: P21W (380)
    Tail Lights: P21/5W (380)
    Signum
    Main Beam: H1 (448) [Facelift] / H7 (477) [Pre-Facelift]
    Tail Lights: P21/5W (382)
    Number Plate Bulb: Festoon 42mm
    Sunny Dartmoor
    Great idea,cheers m8........
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Brilliant idea.
    Worcs/Staffs/Westmids (ish)
    And the boot courtesy light is a C5W Festoon bulb.... No exact part No as 39mm - 42mm length will fit OK.
    Wales
    Great idea.
    Everything looks about right for the Signum; Only thing I can see missing is the bulb spec for the illuminated sunvisor mirror thing
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Good idea, Dont think its suitable for the howto section though, its more suited to the Reference section..
    Wales, UK
    Good idea !!!
    As I can't edit OP, I'll edit this repost with the changes until it's done. Can't seem to find what bulb the sunvisor takes, has anyone replaced a bulb in it before and remember what bulb it was?
    Pre-facelift Vectra
    Main Beam: H7 (477)
    Glove Box: C5W Festoon (39-42mm)
    Boot Courtesy Light: C5W Festoon (39-42mm)
    Sunvisor Courtesy Light:
    Facelift Vectra
    Main Beam: H1 (448)
    Signum
    Number Plate Bulb: C5W Festoon (39-42mm)
  1. Inner Tie Rod Guide
    By aruffell in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2011, 21:42
  2. sky hd tv guide
    By solorider in forum The 'Off Topic' room
    Last Post: 12th May 2010, 12:43
  3. Can I Replace Fog light Bulb for a 100 watt Bulb
    By m300raj in forum Electrical & ICE (including SatNav)
    Last Post: 17th January 2010, 19:33
  4. a how not to guide
    By vectra 2.0 t in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2005, 13:42
  5. boy racer guide
    By chunkster in forum Comedy & Humour
    Last Post: 7th August 2005, 22:58
https:www.vectra-c.comforumshowthread.php99120-Bulb-Guide!
