Thread: windows opening by themselves
    Jan 2010
    kent
    Default windows opening by themselves
    I noticed a similar thread but thought it was worth starting one afresh. I have a vectra bought new with reg 07. For the first two years of its life the windows were perfectly behaved.
    Then I guess a little after the two year service i had the windows opening themselves mysteriously phenomenom. Initially i thought it nay have been an accident with the key fob...but it has now happened a further 5 or 6 times...always with the windows fully open (never partially) and always outside my house....the last two times the car had been parked for a day and two days respectively with windows shut and having not been driven..only for the windows to be opened by themselves on the following mornings.
    I have taken the car to the dealer now twice, no faults have been found and vauxhall seem none the wiser to it.
    The fact that you need to keep the fob pressed for around 8 to 9 seconds to get the windows fully down, and that there has never been an instance where the windows are parially open leads me to the conclusion that it is not my fat arse or clumsy fingers that are to blame.
    I can only imagine that somehow an outside signal is responsible..well this is my conclusion..any other input would be welcome
    Neil
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    u shud record it over night, see what happens. could be a dirty switch? worth taking out and giving a clean, 10 min job.
    PaZ!
    jilava
    did you try lifting the windows and keeping the button pressed for 3 secs after they are fully closed to calibrate the sensors?
    Full Member gibbon7000's Avatar
    lincs
    This has happened to my signum twice and my dads signum once. I do believe plenty of other people have experianced it too.
    My other car. 1972 1641cc slammed beetle. On the road finally!!
    Cambridgeshire
    Quote Originally Posted by andreitone View Post
    I think something like this needs to be done so I can rememeber. I make a habit of checking the windows by pushing the 'up' button for a few seconds.
    Jan 2010
    kent
    thanks for the replies......the fact that it seems to happen a fair while after ive used the car suggests that it is somehow gettting a signal to open the windows..im sure the windows are calibrated properly as the fob allows me to close the windows....if vauxhall know what the problem is they are not letting on to me
    jilava
    you can check that they are calibrated. If they open fully and close fully by pressing the buttons on the doors for 1 sec, then they are calibrated. if not you need to calibrate them as I said earlyer. it's worth checking I think
  1. windows opening with keyfob
    By thehuntedfew in forum Electrical & ICE (including SatNav)
    Last Post: 20th May 2015, 19:25
  2. Windows Wipers and Windows Washers
    By kevrod79 in forum Electrical & ICE (including SatNav)
    Last Post: 19th February 2009, 09:58
  3. Opening Windows with key fob.
    By VinnyPeewee in forum Electrical & ICE (including SatNav)
    Last Post: 24th September 2008, 22:07
  4. Opening windows with key-fob
    By ghostrider in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2008, 21:01
  5. Opening windows via the remote
    By markm in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2007, 00:48
