Thread: VXR gearbox on a 3.2
    Regular Member fuzzbomUK's Avatar
    Milton Keynes
    Default VXR gearbox on a 3.2
    Hi all,
    I was reading a spot on the 3.2Gsi in a Magazine i am sure we are all aware of and i noticed in there a bit saying you could fit the 6speed gearbox from the vxr to the 3.2.
    Ok i know the engine itself is fairly similar but has anyone done it and would there be any advantage to it ie. higher final drive to make it better on fuel on long runs?
    Or better still has anyone done it and can give there input?
    thanks,
    Regular Member bigcarman79's Avatar
    Jan 2008
    Pontefract
    Quote Originally Posted by fuzzbomUK View Post
    Hi all,
    thanks,
    I think the only similarities are the fact they both have 6 cylinders....the rest is very different.........Though fitting the gearbox is probably possible, but wouldnt have thought it will be easy
    Leicester
    The VXR gearbox won't fit. You can use the 2.0T's F40 gearbox but you will also need the 1.9 CDTi bell housing. So a big job and the use of two gearbox's.
    But......................althought the gearbox will fit, it is not clear which flywheel/clutch will be needed.
    Full Member Big Sig's Avatar
    Would also have a very similar final drive so probably not that worth while.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Even if cruising fuel economy was improved dramatically, the cost of the conversion would take a LONG time to recover from fuel economy benefits only.
    Probably a fairly pointless exercise in my book.
    Milton Keynes
    ok well it would be nice to have a closer ratio gearbox.
    I just thought it would fit as the VXR gearbox is an f40 also is it not?VXR box on ebay
    Just get a different insert for your gearknob from a 6 speed car - no-one will notice...
    Milton Keynes
    LOL.. interesting idea but i would rather have a 6 speed box
    Jan 2010
    Cumbria
    On the same topic but slightly different cars ( Did I say Slightly LOL ) can a 6 speed box from a CDTi be mounted to a 2.2 DTi. Are they same bell housings and would it be a straight swap.... or would it be a nighhtmare
  1. M32 gearbox can`t get gear selector back in gearbox HELP!
    By v33tra in forum Engine & Drivetrain
    Last Post: 30th March 2017, 07:43
  2. Gearbox and Gearbox Oil question
    By trickydickySRI in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2011, 17:01
