Results 1 to 10 of 13
Thread: Roof Mounted Monitor
    On a Sabbatical daviek's Avatar
    ayrshire scotland
    Default Roof Mounted Monitor
    As above looking for some tips etc from anyone who has fitted a flip down roof mounted monitor or dvd player. Just received mine and looks easy enough but basically looking for info on things like lowering the headlining , where to mount the base and routing the av cables , powering up the 12v supply etc. Any info appreciated
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    There's a how 2 for the factory fit one that Mav did HERE I fitted just an aftermarket flip down monitor, I routed the power to the boot fuse box down the C pillar and the RCA's down the A pillar.
    ayrshire scotland
    How did your fix to the headlining buddy and did you need to cut it at all. Was thinking of removing my rear interior light for access for the wiring as the monitor has built in lights anyway
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Should be instructions with it Davie follow them and you will be fine or is it an after market one
    Irmscher Insignia CDTI 130
    ayrshire scotland
    Quote Originally Posted by bigmac View Post
    No mounting instructions buddy ..... Chinese made unit
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Good luck
    Regular Member SRIRob's Avatar
    Jan 2010
    Essex
    Dave most of them need the headlining to be cut out then a mounting bracket goes up to the roof with sticky tape then the monitor screws to that and finishes off the edges
    Vehicle : SRi
    Mileage : 137000
    There was a plate that you put on top of the headlining, you then put the monitor on the other side and sandwiched the headlining in between the plate and the monitor. I had to put 5 holes in the headlining, 4 for the screw and 1 for the RCA's. I had to pull the headlining down for access and to make sure it didn't go anywhere near the roof Brace/role bar type thing, I only dropped it one side, so had to take grab handles, AB&C pillar plastic trims off and then just ease it down.
    Full Member spennny's Avatar
    Blantyre
    First of all i put the unit to the roof lining and got a pen and marked where the screws were going to go then I dropped the lining down from the passenger side, removed the sunglass holder and slid my arm in from there to have the backing plate inserted,
    Dont worry about the creases, these have disappeared
    Got the Mrs to hold the unit up on the roof and force the screws thrrough the holes i made, then lined up using touch / feel
    Cables ran along the lining to the passenger side and then down the door pillar , down to fuse box
    Prob not making sense but it worked for me
    ayrshire scotland
    Think thats how mine's fixes buddy , does the headlining not sag with the weight of the unit . And is it sturdy enough when pulling down the screen. PS mines is a 10.4" screen model , also rather thin as thats what made me buy it.
  1. DVD Roof Mounted
    By boxer6364 in forum Electrical & ICE (including SatNav)
    Last Post: 10th September 2011, 21:11
  2. Roof Mounted DVD hatchback
    By lds1973 in forum Electrical & ICE (including SatNav)
    Last Post: 19th March 2010, 00:22
  3. Roof Mounted DVD
    By leeds vectra in forum Electrical & ICE (including SatNav)
    Last Post: 1st May 2006, 21:48
  4. Vauxhall Roof-Mounted DVD
    By leeds vectra in forum Vectra C / Signum Car Chat
    Last Post: 9th March 2006, 23:49
