Thread: Which engine oil???
    Regular Member JonV6's Avatar
    Cardiff
    Default Which engine oil???
    Can anyone clear up my misunderstanding of engine oil specifications?
    I'm trying to find the right oil for my 3.0 V6 diesel but there's a mine field of specs! The manual says the oil must meet ACEA A3/B3 on one page, then GM-LL-B-025 on the next.
    I spoke to the dealer earlier who told me to use 10W-40 Semi-synthetic but the top up bottle I picked up that meets the above specs is fully-synthetic!
    To confuse matters even more I went to the Castrol website and put in my reg. number and it told me to use 0W-30 but didn't mention if it was part or fully synth It did however list the Vauxhall specific GM-LL-B-025 spec.
    I decided I wanted to use Magnatec 10W-40 cos we don't get the temperature range in the UK to warrant using 5W-30 or anything thinner. But I realised I'm then limited to 10,000 miles between oil changes whereas 0/5W-30 is good for 20,000 (I've done 12,000 in the last 10 months) in accordance with GM-LL-B-025 but they don't do it in Magnatec.
    SO.......It looks like it's going to be 5W-30 ACEA A3/B3 GM-LL-B-025!!! The question is......FULLY OR PART SYNTHETIC?????
    Cheers,
    Jon.
    Full Member
    Bristol
    I have a V6 cdti I use 5w 30 but next change it will be 10w 40 I think it better for the engine.
    Regular Member wardy's Avatar
    Chichester
    Quote Originally Posted by sb1uk View Post
    No, the 3.0 needs 5w-30 fully synthetic. It's more expensive than the 10W - 40 but with that engine I wouldn't risk anything else.
    Cardiff
    Quote Originally Posted by wardy View Post
    I kinda figured this was the case Wardy. Can you recommend a particular oil? Castrol recommend 0W-30, at least it's the only one with the GM-LL-B-25 rating. They do a 5W-30 but it only has a VW rating. either way, pricey!
    Mar 2007
    Tamworth
    Quote Originally Posted by JonV6 View Post
    Cheers,
    Jon.
    Doesn't matter, 5W-30 ACEA-B3 GM-LL-B-025 is what matters.
    Specification is everything, leave it to the oil chemists how they make it.
    Full Member Big Sig's Avatar
    just use vx 5-30 fully synth. Its what is supposed to go in that engine.
    Chichester
    Cardiff
    You speak much sense Big Sig. I haven't checked but I'd like to think VX oil will be slightly cheaper than Castrol etc.
    Its all about £10 a litre, not a lot in it for any of them at that grade.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I use Vx 5w30 in my 3.0CDTi and I find the engine noisy when it's warmed up ie. oil is thinner. I think I might use Mobil 1 5w50 for the next change. It meets GM standards.
  1. Replies: 5
    Last Post: 25th January 2013, 17:44
  2. Can I replace a Z19DT engine with a Z19DTH engine, fairly easily?
    By Krusty3380 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 15:24
  3. Replies: 35
    Last Post: 5th May 2012, 15:32
  4. Yellow engine light staying on & engine getting hot.
    By Phil Campbell in forum Engine & Drivetrain
    Last Post: 20th March 2010, 08:56
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
