Thread: Both Rear Inside Pads gone
    Oct 2007
    Wolverhampton
    Default Both Rear Inside Pads gone
    100,000 mile service today. Apparently both inside rear pads have worn through (oops... ). Now this is only it's 2nd set of pads so not terribly upset.
    However I suspect it's down to the calipers sticking a bit. I have all the mechanical ability of a Trout on acid. So although the garage are greasing up carriers and such like. Is it likely to come back soon?
    If so are new calipers the only real long term resolution? And what's it going to cost me. (Because I might just trade it rather than fix it depending on costs)
    Or does it sound very odd it's both inside rears and I should be looking elsewhere for a problem/fix...
    Cheers!
    Regular Member cerbrious's Avatar
    Apr 2008
    Wigan
    very common matey a srip and clean is the way forward its the handbrake mechanism thats the culprit
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Also the caliper is sliding type,the inner pad will always wear quicker,it makes contact first with the disc then the outer is pulled onto the disc,that's why looking through the wheel to check the pads doesn't work out !.
    Oct 2007
    Wolverhampton
    Excellent news. I suspected it was the standard having read some other posts.
    Full Service, Pollen Filter, Rear Disks and Pads. All for less than £350, at a garage 400yds from the house.
    Somedays the reasons behind choosing the Vectra over more exotic cars are quite clear.
  1. Condensation on Inside Rear Driver Side Rear Panel
    By akeem in forum Bodywork & Interior
    Last Post: 26th November 2012, 22:12
  2. rear tyres wearing on inside
    By kirky2k4 in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2011, 20:30
  3. Rear Tyres wearing outside to Inside
    By Benners in forum Suspension, Wheels & Brakes
    Last Post: 28th January 2011, 23:45
  4. Tyre wear in rear inside edges
    By lee gsi in forum Suspension, Wheels & Brakes
    Last Post: 8th January 2011, 14:38
  5. Mintex Front Pads, Rear Pads and Rear Discs
    By The Gas Man in forum Parts for sale
    Last Post: 6th January 2008, 00:34
