Results 1 to 10 of 19
Thread: More Problems
    UK
    Default More Problems
    Took my car out this morning (2006 cdti 150bhp) and noticed a slight whine from under to bonnet which is worse when under load, after a few minute the temp was up to over 95deg. Pulled the car over right away, opened the bonnet and there was steam and a burning smell coming from around the cambelt area.
    From searching to forum sounds like it could be the water pump and or a tensioner. Does this sound possible or is it more likely to be something else. The car has done 160k and had its first cam belt a 80k.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    as it was still running (albeit noisy) then I would doubt that it is the belt or tensioner. Most likely the water pump which isn't timing belt driven on CDTi
    UK
    Quote Originally Posted by Ste View Post
    Car is still running fairly normally just gets hot very quick. What belt does the water pump run from?
    Rochford
    Hi. The water pump is run off the cambelt. Its not driven from the toothed side of the belt but the other smooth side. I have just changed mine with the cambelt. Check the 'how to's' on changing the cambelt and you can see exactly where the waterpump is.
    Rochford
    Just checked the 'How 2's section and its on page 4.
    UK
    Oh i see, that how too makes it very clear, i will take the cover off and have a closer inspection but think I will leave the rest to a mechanic as it looks a little much for my skills.
    Regular Member si_sri's Avatar
    Nov 2009
    TELFORD
    Exclamation
    Hi,
    If the water pump wasn't changed along with the first cam-belt change (highly recommended action) I would suggest its definately the pump whats gone, and is attributing to the temperature etc your seeing. The temp isn't the problem though it's the fact that the pump's pully does drive the came belt (as already mentioned). I suggest not running the car at all because if it does fail it could quite easily drop the belt off and wreck your engine....
    Suggest you get a new pump and cam belt kit fitted asap mate.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Link to 'How to' http://www.vectra-c.com/forum/showthread.php?t=55920
    I would agree with what has been said. Remove the covers and see if the pump is leaking / working etc. I wouldn't drive it either until I know what the problem is. Stat malfunction could be another reason for overheating but not steam or smells. It may be that the pump has seized and the belt burning is the smell.....
    Rochford
    To remove the cam cover is quite a time consuming job as you have to remove the complete engine undertray. Then support the engine with a jack and remove the engine mount before the cam cover will come off. By this time you might aswell carry on and change the waterpump/cambelt as you are at least a third of the way into the process.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    The cover isn't in 2 parts like on other engines? That's not what I expected....
  1. z18xer vvti, problems, problems
    By gstore in forum Engine & Drivetrain
    Last Post: 20th April 2012, 13:33
  2. 1.8 vvti problems, problems problems!!!
    By gstore in forum Petrol Engine related
    Last Post: 3rd March 2012, 01:31
  3. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 2nd October 2011, 21:20
  4. GSi problems
    By Piemyster in forum Engine & Drivetrain
    Last Post: 27th July 2011, 20:11
  5. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
