Thread: Peugeot 106 problems need help
    Regular Member Teefin's Avatar
    SW Scotland
    Default Peugeot 106 problems need help
    Sorry if this is in the wrong place.
    I have a 99 reg 106 Quicksilver for my son to learn in.
    Recently it has started missing after running about 4-5 min if I am driving along it splutters and then clears quickly and never misses a beat again. If however I am stopped for any reason or driving slowly when it starts spluttering and I try an accelerate nothing happens and seems to over fuel as you can smell the petrol but no acceleration. It normally then stalls and struggled to start again.
    It has over 100000 miles however only had one owner who serviced it well and I have had it for over a year between both sons.
    Any suggestions would be appreciated.
    Vectra hasn't missed a beat so far this winter but struggling on the ice with no TC.
    Regular Member poves's Avatar
    lancashire
    It may be a coil pack breaking down , I'm pretty sure the renaults have pencil coils on the plugs , and I've seen a few of those misfiring , so I imagine pugs would be the same .
    Regular Member paul.sessions's Avatar
    leighton buzzard
    mate had a 106 recently with the same sort of problem he thought it was the distributor cap but it was just one of the ht leads going in, he replaced them car runs like new, suppose it could be either of these
    Bristol
    These 106 cars and the saxo have an inherant problems with ECU's as they are the same drivetrain. This also cause running problems.
    SW Scotland
    cheers guys I will check leads etc first hope it isn't ECU.
    Worcs/Staffs/Westmids (ish)
    I had a 106 and later a 306....
    I think it's the lambda sensor, Im pretty sure that year of 106 will have one and it will cause the exact faults you describe.
    Regular Member djr69uk's Avatar
    Midlands
    yeah thinking back my RS2000 had those symptoms and it turned out to be lambda fault. you can test the plugs, leads and coils easily enough, but normally when they break down the problem is there most of the time. the lambda sensor causes the problem after a few minutes due to it needing to get to temp before it starts to operate.
  1. peugeot 206 front end
    By danny567890 in forum General Motoring Chat
    Last Post: 20th October 2012, 01:19
  2. Peugeot?
    By chewy71 in forum The 'Off Topic' room
    Last Post: 25th May 2011, 20:43
  3. peugeot 207 gt
    By twaiter in forum The 'Off Topic' room
    Last Post: 6th December 2010, 17:55
  4. peugeot
    By neilybhoy1888 in forum The 'Off Topic' room
    Last Post: 1st February 2010, 18:05
  5. peugeot 106 ,2003
    By bigron1988 in forum Cars for sale
    Last Post: 28th February 2009, 19:21
