Thread: Emissions Light - Fault Code Help!!!
    Jan 2010
    Cambridge
    Default Emissions Light - Fault Code Help!!!
    Hi all, I am a newie on this site and was hoping someone could help with me a few issues. I have recently had the emissions light come on in my 2003 1.8 SRI dualfuel veccy and had the following faults diagnosed:
    P0100 Mass or Volume Air Flow Circuit Malfunction
    P0110 Intake Air Temperature Circuit Malfunction
    P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
    P0170 Fuel Trim Malfunction (Bank 1)
    P0301 Cylinder 1 Misfire Detected
    The garage has already replaced the ignition coil and the front lambda sensor to rectify these faults with no avail! Clearly the work so far has not been cheap, so am hopefully looking for some help from you guys if possible to steer me in the right direction as the garage seems to just keep on guessing the faults at my expensive.
    Hopefully someone can help, regards in advance......
    Jan 2010
    Cambridge
    Sorry, I also forgot to mention that the temperature gauge also appears to be playing playing up, as it doesent move until after about 20 mins of the engine running. The car is running lumpy and erractic! Hope this helps. Maybe I should be looking at a new MAF????
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    answered in other thread you posted.
    CAN MODS MERGE PLEASE?
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
  1. Fault code P1125 + Emissions light
    By Aaron1976 in forum Engine & Drivetrain
    Last Post: 7th January 2013, 16:52
  2. Z22YH fault code 1191-5a (exhaust emissions?)
    By DaveG in forum Engine & Drivetrain
    Last Post: 3rd July 2012, 17:22
  3. EML light when first starting, no fault code recorded???
    By portreathbeach in forum Electrical & ICE (including SatNav)
    Last Post: 4th April 2012, 21:58
  4. Emissions Light- Fault Codes
    By Stu_2010 in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2010, 21:06
  5. ECU Light & Fault Code help!
    By petesaysblimey in forum Engine & Drivetrain
    Last Post: 24th September 2008, 15:03
