Thread: pug 206
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    confused pug 206
    Hi guys........need your help. my father has a pug 206(for his sins) and when he started it today to warm up on idle-he went out ten mins later and was in red on temp gauge - no fan kicked in ............but he is 70 yrs old and scared to drive it!
    would I be right in thinking eng temp sensor or have any of you guys had a similar experience to this? any help appreciated.
    p.s appologies admin if this is wrong section to post this,
    thanks in advance Andy
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Could be the temp sensor or even the fan motor. Connect the motor straight to the battery to eliminate it first
    Regular Member sparkyt's Avatar
    Thorpe Essex
    Is there antifreeze in it?
    Jun 2009
    bradford
    thanks for the replys guys.........John -wouldn't it be too cold at this time of year for it to overheat even if the motor was faulty?
    yes there is antifreeze in there(I checked)as he didn't have a clue!
    Andy
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Depends where he was driving it mate, was it in town or out on the m/way.
    Is it the 1.1 petrol?
    Regular Member keith1983's Avatar
    Sheffield / Spalding
    Vehicle : Vectra 1.8 SRi
    Engine : Z18XE
    could be afaulty gauge, try starting it when you know it has been sat overnight and see if the gauge goes straight ot the red wihtout it even having time to get that hot.
    Jun 2009
    bradford
    no John its 1.4 auto
    it was just on idle on his drive-frightened to death of driving it, did it after ten mins of tickover............want to get it sorted for him as my parents live miles from any public transport and are isolated where they live......
    does any one know if a code reader that fits mine will fit that and give me any errors?
    thanks again
    Andy
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    One that works on yours should work ok on the pug as it'll be obd2. Give it a try although I'm not sure if it'll give you a code.
    Easiest process of elemination would be to start with the fan motor though as its easy to test
    Jun 2009
    bradford
    will do John, thanks again........
    Andy
