Results 1 to 10 of 22
Thread: illuminating sports button
    Regular Member VECTRA HEAD's Avatar
    Derry
    Default illuminating sports button
    I am trying to get my sports to light up but i don`t know what type of wire to use,i have found a thread on the search forum describing how to do it via connecting a wire from the back of the t/c switch but does anyone have any ideas on the type of wire to use to make the connection possible?
    Regular Member CristianTM's Avatar
    ROMANIA, Eastern Europe
    Look at this picture. The SPORT switch is connected to BCM Module. For any question please ask.
    CristianTM.
    Regular Member P3tchy's Avatar
    Milton Keynes
    If you mean what size wire to use? I would say 1 or 1.5mm should be fine.
    Derry
    what does this mean tristan,it cant be done?Patchy would it be a single strand of wire be ok or something like speaker wire?sorry to sound abit thick but i`m not great with electrical wires.lol
    Hanging Heaton / Batley
    19 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Do you have the link for the thread... i've used speaker wire before when playing with lighting in cars. no prob...
    Basically you've got three inputs - the backlighting with the variable resistor, the LED illumination when the switch is on, and the physical switch itself to turn the system on. They go left to right in that pic. In theory all you need is the 12V power supply to the left had resistor to make it light up...
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    So that means I could link it up to my tuning box which is switchable
    Derry
    the link Lee is found in the search forum under the heading "illuminating the sports button",it is mentioned that the wire was soldered to the led in the t/c switch and then soldered to the sports button
    All what you need to make is connect pin 2 from Sport switch to pin 2 from TC and pin 5 from SPORT switch to pin 6 from TC. On the backside of switch is marked the pin number.
    Good luck !
    CristianTM.
    Derry
    thanks cristian for the info,just out of curiosty,where did you get the info on the pins?
  1. sports button
    By caitlin6 in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2013, 19:53
  2. sports button
    By vinty firth in forum Styling
    Last Post: 29th December 2011, 19:15
  3. sports button
    By beefycol in forum Vectra C / Signum Car Chat
    Last Post: 19th December 2007, 15:57
