Results 1 to 10 of 23
Thread: engine temp gauge
    Regular Member ggg1979's Avatar
    Kettering
    Default engine temp gauge
    how long does it take for you gauge to show a reading. I've got a 57 plate vectra 1.9 D SRI drove to work this morning (very cold!) and in the 20min it took the temp gauge did not go up! Only had the car a few days!
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Was the heater working OK?
    If heat is coming out of the vents, then I wouldn't worry. Diesels take a long time to fully warm due to them being more effecicent at converting fuel to motion and also there is quite a lot of metal to warm too. Heat loss to ambient will also be high due to the cold weather.
    Worcs/Staffs/Westmids (ish)
    Mine is barely moving in this weather (1.8 petrol). It just about touched 60 by the time I got to work after a 30min drive.
    Kettering
    its seemed to take a while to get hot, and even then was not as hot as I would have expected
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    TBH, I wouldn't worry about it, but if it still doesn't get warm when the weather gets a bit warmer then it may need investigating. Does it get fully warm when in traffic etc?
    Kettering
    No, gauge just sits on zero all the time, but not driven it for longer than 30mins yet
    Regular Member maurauth's Avatar
    Southampton (Locks Heath)
    I had the same thing with my 1.8 Vectra, I would drive journeys of up to 30 mins to get to work / gfs house and the temp guage wouldn't leave the bottom. So either my car had the same problems as yours or it's not a problem.
    However my 2.0T Siggy warms up a lot faster, 5mins is enough to at least move it from the bottom to 80.
    Regular Member woody in shetland's Avatar
    Shetland Islands
    Trim : Sxi
    Engine : 2.2 dti
    Year : 2002
    Must be a veccy thing, mines being doing that for the last couple of years, somedays i can drive in to work and it won't move and other days it will move. I reckon in theory if you left her running long enough it would eventually start to rise, i wouldn't worry about it though
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    On 1.8s the temp gauge should start to raise after about 4/5 miles and then sit on at least 85 and go to 90 (that being half way up the scale) in traffic, even in this weather. But mine only did this after changing the thermostate last year before that it would not go above 70. The temperature rating on the new thermstate was 92. The job of the therm' is to open and close according to the engine temp so as to maintain a steady and correct engine temp, so if this is not happening you could have a faulty thermostate. On 1.8s the change is a very simple job.
    Regular Member 19CDTi's Avatar
    Jul 2009
    Perth, Scotland
    I drove around town in my 1.9 8v in -6 degrees last night for about 25mins before it moved! lol it does appear to take a lot longer in this weather but the heater works so im happy! lol
  1. Engine Temp Gauge not quite right
    By Di frost in forum Engine & Drivetrain
    Last Post: 30th December 2011, 12:52
  2. engine coolant/temp gauge/heater
    By redmoog in forum Engine & Drivetrain
    Last Post: 1st December 2010, 21:37
  3. engine coolant/temp gauge/heater
    By redmoog in forum Troubleshooting
    Last Post: 1st December 2010, 21:27
  4. Engine Temp gauge
    By cooky in forum Vectra C / Signum Car Chat
    Last Post: 3rd October 2009, 12:21
  5. Engine temp gauge not working ???
    By andythilo in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2008, 21:36
