Thread: revs not dropping when changing gear
    Regular Member billpayer's Avatar
    Oct 2009
    essex
    Smile revs not dropping when changing gear
    hello again
    Had this problem for a while now where by when I change gear the revs dont drop as as soon as I lift the of the gas and dip the clutch resulting in poor gear changes ( they do drop but not quickly enough)
    Its worse between 1st and 2nd and 2nd and 3rd when pulling out in to fast traffic when you need to take the revs past 4000
    Any ideas?
    Ive seen the how2 on cleaning the TB, do you think this would help it?
    2.2 direct
    Mileage : 000
    I wonder if cleaning the Air control valve might cure the problem, as it might be gunged up or sticking.
    May 2008
    Derbyshire (south)
    I had this too, to start with i changed the way i drove, lifted off before depressing clutch. I then had it checked on diagnostics, it apparently is a issue of "overrun", that can just be changed on obdII iirc.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Thats how it is on the 2.2 mate, there is no ICV on the 2.2's so cant be that. Its the downside of the fly by wire TB. If you have the sports button it does alter it but if not there's not much you can do but get used to it.
    Oct 2009
    essex
    Hmmm not sure I can get used to it lol, surely it didnt leave the factory like it. I had an Alfa 147 before which also had FBW controls but I never had any issues with that. I dont have the sports button so a no go there
    and whats an obdII iirc?
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    id clean out the throttle body bud might be gummed up
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    It's part of the throttle damping algorythm. To get a smooth and relaxing cruise at higher speeds (ie motorway) the throttle is damped, which means that you may see a small rise in RPM when initially pressing clutch and lifting off acc pedal. Normal and you can't really do much about it. Sport button reduces the throttle damping
  1. engine revs dropping when cold 03 2.2DTI
    By stuartcorbitt in forum Engine & Drivetrain
    Last Post: 7th July 2011, 18:15
  2. Revs surging up and then dropping back when giving to some welly!
    By fm-online in forum Engine & Drivetrain
    Last Post: 14th March 2011, 15:01
  3. Revs Dropping
    By mikeq in forum Vectra C / Signum Troubleshooting
    Last Post: 30th January 2011, 18:52
  4. revs dropping and dying out
    By keef2610 in forum Vectra C / Signum Troubleshooting
    Last Post: 18th April 2009, 12:16
  5. Revs dropping when coming to a standstill
    By FinestJammy1 in forum Engine & Drivetrain
    Last Post: 6th December 2008, 12:33
revs dont drop when changing gear
revs not dropping changing gear
corsa c 1.4 revs not dropping when changing gear
vauxhall insignia 160 cdti revs not dropping straightway
insignia holding revs
zafira engine revs not dropping when changing gear
corsa c revs not dropping
vectra c revs not dropping between gearvchange
revs not dropping whrn changing from 2nd to 3rd gear
Vectra c 2.2 direct when i change gear up the revs go up a bit
insignia revs between gear
revs dont drop when gear changes
vw golf engine holds revs between gears
insignia cdti revs dont drop when changing gear
revs dropping on geat change ds3
corsa c revs dont drop between changes
vevtra c 3.2 v6 holds revs between gears
vectra c holds revs between gears
vw golf revs go up when clutch is dipped
corsa revs dont drop when changing gear
when changing gears why does engine not drop revs
vectra v6 cold start revs dropping
vectra vxr holding back between gear changes
revs dont drop when clutch is pressed
corsa lite revs dont drop when shifting gears
