Thread: HELP please !! how do you replace os curtain and seat airbags
    newbury
    Eek HELP please !! how do you replace os curtain and seat airbags
    Hi guys had a slight miss happ last night involving some ice and a kurb oops. i managed to set off the curtain and seat airbags drivers side . does any body know how to change these ?? i am a mercedes commercial mechanic so have no problem with getting my hands dirty any help would be fantastic .
    Regular Member deano1's Avatar
    leicester
    Vehicle : Vectra estate
    Trim : Sri xp2
    Engine : 1.9 cdti 150
    Mileage : 100000
    hi roof airbag quite easy first you will need to remove headlining then the airbag is held by 4 or 5 small blots and 1 plug.
    as for seat i would think you need to dismantle the seat and undo the bolt.
    11 Post(s)
    Won't the airbag ecu also require changing?
    Nottinghamshire
    Possibly. I think it depends on the age of the car - early cars have an airbag ECU that can't be reset - it has to be replaced after airbag/seatbelt pre-tensioner activiation. Also, I don't think you can de/re-program the early ECU's so swap between cars either.
    The ECU in later cars can be reset after activation but I'm not sure whether they can be moved between cards.
    There's always airbag ECU reset services - if you trust your life to someone you find on somewhere like eBay.
    Jan 2014
    newtownabbey
    Vehicle : vectra
    Trim : sri
    Engine : z19dth
    I had the same thing happen to me last night comingbhome from work...i zoned out for a moment...car veered over and rear wheel knocked off roadside wall...had a wee dent in wheel arch but o/s curtain and drivers seat airbag deployed ffs...just round the corner from my house too...im so angry with myself....my car is an 08 1.9cdti btw...is this a straight forward replacement and fix?
  1. For Sale: Charcoal Seat Airbags
    By Ian-Highlander in forum Parts for sale
    Last Post: 2nd April 2012, 12:46
  2. curtain airbag connector
    By alexiker in forum Electrical & ICE (including SatNav)
    Last Post: 24th March 2011, 12:49
  3. Replies: 3
    Last Post: 15th September 2008, 21:56
  4. Curtain airbags and mike cables
    By JuzzyD in forum Electrical & ICE (including SatNav)
    Last Post: 18th March 2007, 14:27
05 vectra roof airbag replacement
replace astra j seat airbag
