Results 1 to 10 of 16
Thread: Stupid Caliper Piston doesnt retract...
    Northampton, UK
    Angry Stupid Caliper Piston doesnt retract...
    Well, after the hassle of the brakes squealing, I did everything I could, copperslip'd the rear of the pads etc, bled the system, greased the slider bolts...
    I've now resigned to the fact that I must have a sticking piston. Ive followed every bit of advice and nothings worked... it moves out... but not in!
    But before I bother sending my calipers to be reconditioned and all internals, seals etc replaced next week... (Does £125 sound ok?)
    I'm going to assume/guess that it's not the master cylinder, ABS pump or servo etc that could be faulty as its only the single caliper???
    Its getting more than annoying now, the drivers side just rubs and grinds when they're cold, but once they get warm, then hot... the car struggles to move sometimes! And that's were the problem of taking it to a garage kicks in, they never drive the car long enough to see/feel what happens.
    So, I'm going to see if Vauxhall Fareham will have a look on Tuesday before I do anything else drastic, but I welcome all comments and advice from everyone on here, as always.
    Regular Member davree's Avatar
    Warton
    Vehicle : Insignia
    Engine : 2.0 CDTI (160)
    Year : 2010
    Mileage : 26000
    Is it front or rear matey?
    I just had a rear replaced on mine and the caliper (brand new) was only £70 (excluding labour) so I would get a new one rather than get it re-conditioned!!
    Northampton, UK
    Its the front, 314 setup.
    Wales
    Its a dead easy DIY job; rebuild kit for both calipers is approx £30. If you can fit the 314s yourself then rebuilding them is childs play in comparison.
    On the 314's the caliper piston is alloy as is the caliper body, so I think that sticking (due to a corroded piston or body) is unlikey.
    Glasgow
    I would get a new caliper no messing about and the exchange fee you get back brings the price down a lot.
    Regular Member simon1's Avatar
    Oct 2007
    Leicester
    Vehicle : Vectra elite
    Engine : 1800
    Mileage : 80000
    are they std callipers . if so will have a pair of mine as upgrading the rears of mine to vxr vented ones this week end
    Northampton, UK
    Where do you get the kit from? I'm just going to put my 302's on this weekend, then probably look at striping them or sending them off for a refurb.
    Wales
    BiggRed callipers – stock item from memory
    Seriously mate, by the time you take off two sets of callipers & disks, then refit another set, you could easily refurb a 314mm caliper. I reckon 20 mins. Its only two seals; a fool could do it.
    Clamp brake hose
    Remove sticky calliper
    Push out piston with air supply (I used a footpump – protect piston with rag or it flies out!)
    Pop out old seals
    Squirt brake cleaner into caliper
    Asses condition of caliper/piston
    Refit new seals
    Fit caliper to car
    Bleed.
    Done. 1.5hrs work max – sub 60mins if your quick!
    May 2008
    Tyneside
    Have you tried dealer, I was quoted £56 for a reconditioned rear caliper for a 1.8.
    Northampton, UK
    Sounds easy... I bet it's not LOL
    have you done it to the 314 setup?
  1. caliper piston rubber gator
    By N14 in forum Suspension, Wheels & Brakes
    Last Post: 17th June 2012, 21:29
  2. caliper piston size
    By marktaylor in forum Vectra C / Signum Car Chat
    Last Post: 31st March 2012, 22:39
  3. rear caliper/piston problems
    By rec in forum Suspension, Wheels & Brakes
    Last Post: 8th October 2010, 21:37
  4. HELP!!! caliper piston seal...
    By danBoy in forum Suspension, Wheels & Brakes
    Last Post: 13th December 2009, 12:04
  5. Compresing rear caliper piston.
    By Aubergine in forum Suspension, Wheels & Brakes
    Last Post: 14th October 2006, 19:03
