Results 1 to 10 of 18
Thread: EGR and poor starting
    Jul 2009
    Leicester
    Default EGR and poor starting
    Problem 1:
    Spanner come on when engine is warm and accellerating over 2500rpm, cuts out power and black smoke from rear. I have had the MAF sensor renewed twice and have taken off the EGR and manifold and cleaned out, i also had my boost pipes changed but fault still occurs.
    Problem 2:
    Had plugs changed but vehicle still troublesome to start. Turns over but doesn't fire up for 2 mins. When turning white whispy smoke comes from tail then when it fires up a big cloud of smoke. I suspect there is moisture in the fuel system somewhere but not too sure.
    I also had fault P0100.
    I have also tried Wynns EGR cleaner in the air inlet after the MAF but this did nothing.
    PLEASE HELP SOMEBODY, im pulling my hair out
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I had huge clouds of black smoke from the rear of my V6CDTi once it was on boost. It was "just" a faulty EGR and 300 Euros later it doesn't smoke.
    Jul 2009
    Leicester
    great. Thats just what i wanted to hear
    Jul 2009
    Leicester
    any advances?
    Aug 2009
    Havant
    don't just clean the EGR - the solonoid has likely become corroded and stuck open, file the corrosion off it with a metal file or bench grinder etc
    that will hopefully save you needing to spend a chunk of money on a new one
    Jul 2009
    Leicester
    wheres the solenoid?
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    check the how 2's section you will find it a mass of usefull information regarding removing / cleaning these type of parts.
    Stockton on Tees
    Does yours have a fuel drain to remove water. Thers a thread running now on new post page about draining water from filter.
    Jul 2009
    Leicester
    done the fuel drain, no improvement. If anything its worse
    Jul 2009
    Leicester
    any ideas people, think i'm ready to pay someone to trash it!!!
  1. Poor Starting
    By Bredsticz in forum Engine & Drivetrain
    Last Post: 2nd May 2012, 23:55
  2. poor starting
    By tomo610 in forum Engine & Drivetrain
    Last Post: 15th January 2012, 19:21
  3. poor starting
    By kmx racer in forum Engine & Drivetrain
    Last Post: 26th July 2011, 22:51
  4. Poor starting
    By Croxley in forum Engine & Drivetrain
    Last Post: 23rd March 2011, 20:25
  5. poor starting
    By m1ke823146 in forum Engine & Drivetrain
    Last Post: 2nd November 2009, 12:14
