Results 1 to 10 of 26
Thread: Tyre grip
    Regular Member shadow's Avatar
    Mar 2007
    Rotherham
    Default Tyre grip
    Just wonderd what others on here think about the grip from there tyres on ice/snow. I have Falken FK452 ON 19" snowflakes, and grip is terrible to say the least.
    I`m not sure if this is a characteristic of this size of wheel, or whether its the rubber or even to higher tyre pressure. Any thoughts welcome
    Full Member Big Sig's Avatar
    ice or snow grip will always be bad due to the levels of friction involved. The tyre width and weight is also a factor.
    Thats why winter tyre's are normally narrower and a smaller diameter.
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    And the compound used,most high performance tyres are "summer" tyres below 7 degrees they just don't work,michelin even say the Ps2 isn't suitable for use in snow or ice !
    Mar 2007
    Rotherham
    I suppose its hard for the tyre manufactures to make an all year round performance tyre.
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    You have got to remember to adjust your style of driving to suit the conditions.
    Narrow tyres ars best fro snow or soft ground, but if you just use a little less gas and take it slow but steady most modern cars will get you where you want to go.
    3.2 v6 Signum and loving it
    Sep 2009
    Audley STAFFS
    Quote Originally Posted by shadow View Post
    my 912s very bad in snow or ice, these Falkens just don't work below 7/10 degrees
    Mar 2007
    Rotherham
    Quote Originally Posted by Johnsdutton View Post
    "Less gas" I could not stop from 10 mph on a slight downhill slope even though i applied the brakes (gently) 40 yards from a junction. Luckily nothing was coming so I let the car slide into the main road and regain grip on the well gritted surface.
    This has never happened to me in my nearly fully loaded transit van before, running on the cheapest tyres that lease companies fit.
    Regular Member Dose's Avatar
    Falkirk/dunfermline/alloa
    I have 452's on the front of my 20's its pretty much down to the width..as said narrowness wins in this weather.
    Regular Member Cruize's Avatar
    South East
    Is it really about the tyre? I know to a degree yes it is as they all perform differently (at warmed temperature) but if thick snow fills the tread on your tyre it doesn't matter what tyre you have, your on slicks and ice skating.
    Worcs/Staffs/Westmids (ish)
    They could, but if they did.... The tyre would be SO soft it wouldn't last a summer, it'd be considered to expensive and car forums like this one would be slagging them off relentlessly. What we get as a result is a compromise :/
  1. Bing bong when no grip?
    By Veccy55 in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2013, 15:18
  2. Snow tyres better grip with this.
    By Bigtee in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2011, 20:26
  3. Get A Grip Man
    By ditchp in forum Comedy & Humour
    Last Post: 30th November 2007, 14:22
  4. Grip in the snow
    By Swatty in forum General Chat
    Last Post: 21st January 2007, 20:36
  5. Cunning Plan to get more grip...
    By nutron in forum Vectra C / Signum Car Chat
    Last Post: 25th December 2005, 14:04
