Thread: compression z22se
    Regular Member delboy2028's Avatar
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    Default compression z22se
    what is the correct compression for a z22se engine in a 2003 vec
    mine is between 8 - 9 bar is this a problem or shal i not worrie?
    Regular Member davree's Avatar
    Warton
    Vehicle : Insignia
    Engine : 2.0 CDTI (160)
    Year : 2010
    Mileage : 26000
    Compression of a Z22SE should be between 12 and 15 bar with a compression ratio of 10.0:1 so yours does seem a bit low!!
    I have read however that unless you do a compression test on these engines without being connected to vaux diagnostic equipment or similar you wont get a true reading as the throttle valve is electronically controlled and needs to be controlled by the vaux equipment.
    HTH
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    ok then so just dont worrie hahaha am sure its fine got timimng chain to do soon so on with that
    Warton
    Vehicle : Insignia
    Year : 2010
    Mileage : 26000
    Quote Originally Posted by delboy2028 View Post
    Good luck with that not something I would like to tackle myself TBH
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    hopfully wont to be bad
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Pop into the 2.2 site, z22se.co.uk. They'll be able to tell you real world figures mate. If your compression is pretty much the same across the 4 bore's then you'll be fine. If a drop of oil in the cylinder raises the compression then the rings might need looking at.
    Vehicle : SRi
    Mileage : 137000
    I see your already on there
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    just lol
  1. No compression cylinder no4
    By r9 nml in forum Engine & Drivetrain
    Last Post: 23rd November 2012, 19:43
  2. No compression in cylinder no.1
    By boodoo warrior in forum Engine & Drivetrain
    Last Post: 23rd February 2012, 00:36
  3. help needed...how do you compression test a z22se engine
    By Miketwinny in forum Engine & Drivetrain
    Last Post: 4th September 2011, 00:11
  4. Engine Compression
    By plasma in forum Vectra C / Signum Car Chat
    Last Post: 21st July 2010, 22:00
compression test on engine z22se
z22se compression readings
z22se cylinder compression value
compression ratio z22se
z22se compression psi
z22se no compression on 2 cylinders
z22se compression test
z22se compression
z22se compression values
