Thread: GSi Exhaust System onto 2.2DTI
    Oct 2009
    Swindon
    Default GSi Exhaust System onto 2.2DTI
    Got offered aGSi system at a great price, I'm assuming this would fit onto my 2.2DTi with at worse only having to reduce the bore size on the front of the centre section?
    Can anyone confirm before I go ahead and purchase?
    Leicester
    The system will hang under the car with the same mountings, but you will need to have the front section totally changed as the 2.2 DTi and 3.2 V6 downpipes are completly different so it won't be a direct fit.
    Bore size, this is different so you may see some negative effects as the system is design to run on a normally aspirated V6 and you want to run it on a forced induction diesel.
    Personally, I wouldn't fit it.
    Oct 2009
    Swindon
    ah ok. Only really wanted it so I had twin rear boxes, I was thinking I could cut and weld in the Y section then just use both GSi rear boxes.
    Regular Member bish's Avatar
    peterborough cambs :P
    it will fit, but you will need a stepped pipe that goes from 45mm to 55mm cant remember the exact size, these are available from most moto factors, but like mav said you will go from say 45mm to say 55mm, not sure how this would affect your particular car
    Full Member Big Sig's Avatar
    The bore size wouldn't make a massive difference as turbo's don't really need back pressure like N/A engines.
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    67 Post(s)
    Vehicle : insignia
    Trim : irmscher
    My exhaust is from an 18 petrol i believe i had to make the new one bigger at the end so it fitted my front pipe,touch wood ive had no problems
    Irmscher Insignia CDTI 130
  1. cat exhaust system
    By mark1.9cdti in forum Vectra C / Signum Car Chat
    Last Post: 8th May 2011, 11:28
  2. My New Exhaust System & a few of the Car
    By Sean-2.2Direct in forum Quick Photo Album
    Last Post: 23rd February 2010, 13:19
  3. New exhaust system
    By damadom in forum Petrol Engine related
    Last Post: 29th January 2009, 14:01
  4. Air in system 2.2dti
    By westie in forum Engine & Drivetrain
    Last Post: 24th September 2007, 13:09
