Page 1 of 5 123 ... LastLast
Results 1 to 10 of 45
Thread: strange dash electrical fault
    Brockley-south london
    Default strange dash electrical fault
    I've got one problem that after using the steering for a bit the traction control light comes on then the steering wheel comes on the dash with a "!" through it. I think thats a CIM fault.
    These last couple of days the battery light either falshes or stays on for a bit with the abs light, taction control light and the dials/gauges stop working. I haven't got a clue where to start looking. Has anyone else expirienced this at all or could give me some pointers to what the problem could be
    cheers in advance
    More problems today. The lights are all still coming on but i switched the car off and went into the petrol station. When i came out the car wouldn't start and could only hear clicking. Rolled it forward a bit to bump start it and couldn't get rolling fast enough. Tried the key again and started.
    Is it pointing to the CIM causing all of this?
    Regular Member cerbrious's Avatar
    Apr 2008
    Wigan
    sound like an altornator to me matey check the batt voltage and the voltage accross the batt terminals when running
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Also try looking for a dirty ABS plug, I had the same problem and cleaning the plug solved it. Its a common fault along with the CIM on early Vec C's
    Full Member Big Sig's Avatar
    check the battery too.
    I'll check the alternator tomorrow. Need to check the abs plug also. Then i think it's time to get the CIM replaced
    Another thing i had was that i couldn't turn the rear heated screen on either just before it refused to start and i've read about that somewhere also
    Quite a few things to check lol
    cheers
    Apr 2008
    Wigan
    slow down big fella start small scheck everything before replacing a very expensive component like a CIM
    I've been putting off the CIM for a while. I had a friend check on op-com and it came up steering angle sensor but hasn't come up for ages so forgot about it.
    The recent problem with the battery warning light and not starting has made me want to sort it now.
    I'm checking the plug first as it seems when the car jolts or goes over a bump the dials start working again then the car/spanner light comes on.
    Full Member Robsey's Avatar
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    If I remember correctly, I have heard of few main causes for this type of fault...
    First and cheapest = Check and clean the ABS Module plug.
    Second = check wires to / from the battery, earth points and alternator / starter connections for security and cleanliness.
    Third = Could the Battery be on it's way out. (Sluggish starting in the recent cold weather)
    As Cerbrious said above...Don't even think of the CIM module except as a last resort!! - Too damned expensive.
  1. electrical fault please help
    By adamuk14 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd February 2012, 01:26
  2. Possible electrical fault...
    By Higgsie1 in forum Engine & Drivetrain
    Last Post: 14th October 2011, 04:07
  3. Strange electrical problem - please read & help.
    By Vaux-Man-G in forum Electrical & ICE (including SatNav)
    Last Post: 7th September 2011, 08:46
  4. Strange electrical problem regarding radio controls on steering wheel
    By eaglepva in forum Electrical & ICE (including SatNav)
    Last Post: 12th January 2011, 17:36
  5. Help (Electrical Fault)
    By Badger59 in forum Vectra C / Signum Car Chat
    Last Post: 30th October 2010, 19:54
rac-hp 103 signum
