Thread: Stuttering engine when engine is cold
    Regular Member chris_sri's Avatar
    New Mills, High Peak
    Default Stuttering engine when engine is cold
    I hope someone can point me in the right direction with a problem i'm having!
    When I start my 2003 1.8 sri from cold it seems to idle ok, but as soon as I set off, the engine bogs down, is very lumpy and stuttery. This only lasts a minute or so and then it's fine. It doesn't seem to matter what the outside temperature is, it only does it when the car is stone cold.
    Help Guys!
    Regular Member delboy2028's Avatar
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    i have a similar problem but mine only happens on acceleration in any weather condition hot or cold engine idle or moving
    Regular Member cerbrious's Avatar
    Apr 2008
    Wigan
    any engine management lights coming on
    sound like possibly a problem with the temp sender for the ecu almost sounds like a car with manual choke trying to drive it away with no choke
    Quote Originally Posted by cerbrious View Post
    No lights at all.
    You are spot on with it sounding like an old manual choke car that needs a good dose of choke.
    Apr 2008
    Wigan
    there will be a sensor for temp that goes straight to the ecu this may well be your puppy
  1. Z19dth stuttering stationair when cold
    By genesisfm in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd December 2012, 02:28
  2. Oil Change - Hot or Cold Engine?...
    By snapsnap in forum Vectra C / Signum Car Chat
    Last Post: 15th March 2011, 15:00
  3. Replies: 9
    Last Post: 7th July 2010, 14:54
  4. engine light on when cold
    By michael cummings in forum Engine & Drivetrain
    Last Post: 11th December 2009, 23:13
  5. Topping up engine oil... engine warm or cold?
    By Quinten in forum Engine & Drivetrain
    Last Post: 15th May 2008, 18:39
