Thread: error codes
    Regular Member delboy2028's Avatar
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    Default error codes
    hi i am new to the vec c pluged my op-com in today when i got home from buying it and got these codes no eml light on at all tho
    B3114 - Remote-Key 1 Not Synchronized
    (00) - Not present
    B3794 - Switch Cruise Control Circuit Malfunction
    (08) - Not present
    C1531 - Steering Angle Sensor System Voltage Circuit Low Voltage
    (03) - Not present
    C1550 - Replace Electronic Control Unit (ECU)
    (37) - Not present
    B3916 - No Communication With Alarm Siren
    U2139 - Invalid Data from CIM (Steering Column Module)
    (00) - Not present
    (7F) - Not present
    B1330 - System Voltage Malfunction
    i am confused as not use to some of them as there not same as vec b lol
    Have you cleared them to see if they come back?
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    i have cleared them yes i just have not ran the car since i cleared them as it was l8 and am in till tomorrow
    Check to see if they come back in a couple of days. Could all be red herrings (fingers crossed)
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    ok will post back in a day or so if they come back
    Regular Member cerbrious's Avatar
    Apr 2008
    Wigan
    usually are false code but seen as there all not present i really wouldnt worry about it
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    drove here today for an hour read codes again after i cleared last night this is what i get now
    (08) - Not present
    P0567 - Cruise Control "Resume" Signal Malfunction
    (00) - Not present
    P0568 - Cruise Control "Set" Signal Malfunction
    (00) - Not present
    (03) - Not present
    (7F) - Not present
    my car still pops nd farts has no power
    Derby
    Do you have cruise control? and does it work?
    milton keynes
    Personally , I would check that the 3 x switches are fine on the left arm. In opcom you can check this. These are the turn on CC (cruise control) , CC up and CCdown.
    northern ireland
    (03) - Not present
    have this code on my car and my power steering isnt working could it b the sensor?? also have c1523 03
  1. (error codes)
    By tomo610 in forum Vectra C / Signum Troubleshooting
    Last Post: 28th June 2012, 20:07
  2. error codes
    By tomo610 in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2012, 20:33
  3. 3.2 error codes help please
    By gibsonk in forum Engine & Drivetrain
    Last Post: 28th January 2012, 13:03
  4. 3 error codes
    By Hydravox in forum Engine & Drivetrain
    Last Post: 20th April 2011, 12:14
  5. error codes
    By bower in forum Engine & Drivetrain
    Last Post: 7th November 2010, 23:01
p0567 eroare vectra c
