Originally Posted by
Robsey
I would not cut down the aerial to make it shorter.
There is a technical reason to do with wave lengths and impedences etc, that should / would affect the signal reception, however if the Tigra has a shorter aerial, and is fitted with the same style of radio head-units, then I would buy the Tigra mast instead.
Note there is a distinct change-over period for pre October 2004 and post october 2004 vehicles / radios.
As said correctly above, the Sat Nav Aerial is a little block built into the base of the aerial mount, and so won't be affected by the radio aerial, however the TMC / Traffic Master system could well be affected by the "radio aerial".
TMC and TM signals are sent along side the standard radio signals of some radio stations such as Real Radio, Classic FM and some others.
The unit in the driver's side rear wing on some pre October 2004 models is a traffic master unit...not a sat nav unit.
The sat nav itself is built into the head-unit of a CD70, NCDC2013 or NCDC2015.
