Results 1 to 2 of 2
Thread: fuel filter change vec c 2.0t
    staffordshire
    Default fuel filter change vec c 2.0t
    hi is there a certain way of doing this/how do i do this cheers
    Regular Member cerbrious's Avatar
    Apr 2008
    Wigan
    really easy matey its just in front of the drivers side rear wheel jack her up and use an axlestand you need to squeeze in the two little button/tab parts of the clip and wriggle the fitting off its a bit stubborn and you may damage the button/tab part but they should have been provided with your new filter once there both off just remove the filter
    and as they say in the haynes refitting is the reversal of removal making syre you use the new clips and that the connections seat on properly.
    also make sure direction of flow is correct (arrow on the filter should point to the front of the car) and that there are no leaks when running.
  1. 2.2 dti fuel filter change
    By marc vectra sri in forum Troubleshooting
    Last Post: 8th October 2012, 08:57
  2. Fuel filter change?
    By parky1 in forum Engine & Drivetrain
    Last Post: 13th August 2011, 22:24
  3. Fuel filter change
    By juggernaut in forum Engine & Drivetrain
    Last Post: 5th March 2009, 16:18
  4. How to change fuel filter?
    Last Post: 31st January 2009, 14:48
  5. 1.9 Fuel filter change
    By Keith Jones in forum Engine & Drivetrain
    Last Post: 11th October 2008, 21:11
changing fuel filter vectra flow direction
fuel filter vectra c 2.0t
