Results 1 to 10 of 22
Thread: day running lights? any easy fit ones
    Sep 2009
    St Albans Herts
    Default day running lights? any easy fit ones
    read that from 2011 all new cars will have led day running lights, thought it would be nice to change my from spot/driving lights to led, any easy way of doing this (obviously don't want bulb warning lights on all the time)
    strange how things come around again, first fitted to saabs and volvos in the 70's and 80's now back again
    Regular Member cerbrious's Avatar
    Apr 2008
    Wigan
    DTRLs can be activated via tech 2 on any vectra
    Sep 2009
    St Albans Herts
    Quote Originally Posted by cerbrious View Post
    i don't know what that means!
    Apr 2008
    Wigan
    DTRL's Day Time Running Lights's can be activated by Tech2 (dealers computer) or similar (op-com vaux com)
    gives you the option of either fogs, sides or dipped beams to come on with the ignition
    Full Member Robsey's Avatar
    North East Cheshire
    10 Post(s)
    Trim : Energy
    Mileage : 131,000
    I don't think op-com will program this function...it is mainly a diagnostic tool.
    However I will be happily advised otherwise.
    You probably know better than me Gareth!!.
    but yes, the daytime running lights can be programmed via tech 2.
    Full Member Penfold101's Avatar
    He can do Steering Angle Sensors too...
    Apr 2008
    Wigan
    yup does do em tried it on mine! i was bored so was playing hence i thought id seen something bout steering angle sensors and low and behold
    You calibrated yours even though it didn't need it...? Now THAT'S boredom for you...
    Apr 2008
    Wigan
    nah just went into every setting and menu i could having a look see lol
    North East Cheshire
    10 Post(s)
    Trim : Energy
    Mileage : 131,000
    Aye, but will it "program" the day time running lights.?
    the steering angle sensor callibration is a bit like a reset function.
    I know I can reset DTC's, Reset the service timer, reset and reprogram the immobilizer functions and the keys oh and the airbags.
    I've had Op-Com for about 12 months now, but have never found any way to do any functional programming.
    Hence why I stated "mainly for Diagnostics", with the odd reset facility.
    It would be nice also if I could find the software for a 1994 C18NZ...but that's another story.
    So back to the point of the thread...
    If you work out how to do the DTRL's,Gareth, then let me know!!
    (Call it a challenge if you like!!)
  1. Day running lights will they fit??
    By BooDaChris in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2013, 11:44
  2. led dash lights and side light running lights
    By fjaimo10 in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2012, 21:21
  3. running lights
    By Tam80 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd October 2010, 08:26
  4. LED day running lights
    By trucker in forum Insignia Chat (READ ONLY)
    Last Post: 18th June 2010, 11:26
  5. Easy wire path? LED lights front Grill?
    By keithsimmo in forum Electrical & ICE (including SatNav)
    Last Post: 6th February 2010, 18:29
