Results 1 to 3 of 3
Thread: HVAC problems with 3.2 vec C
    Apr 2009
    Huddersfield
    Default HVAC problems with 3.2 vec C
    Hi, got a problem with my veccy. 1st of the heater only blows cold air, no matter what the temp is set to, its just freezing, 2nd problem the engine cooling fans come on from start up even if the engine is cold, stop the engine - keys out, they stay on the over-run for 5+ minutes. Not loosing any water, performance was fine until the fault with the cooling fans, with these running the engine cuts out intermitently, i think this is to do with how the ECU is fuelling the engine ( it thinks its hot when its not )
    I had the water pump changed about 6 months ago.
    Please help , many thanks
    Regular Member wotsthestory's Avatar
    Jun 2007
    Carshalton
    Engine : 3.0 CDTI
    Mileage : 103000
    Coolant Temperature sensor duff, which will cause the rad fans to run and the engine will run to cold making it run less than efficient!
    Apr 2009
    Huddersfield
    Quote Originally Posted by wotsthestory View Post
    Yeah a few people have said that so i got a new one, i didn't fit it but i simply just pluged it in, no joy. just to be sure i changed the right sensor, where is it and what does it look like, the one i got from vx kinda looked like an all brass spark plug. Also thank you for the quick reply
  1. HVAC control main button doesnt work!
    By Johnny-B in forum Vectra C / Signum Troubleshooting
    Last Post: 26th June 2012, 18:27
  2. z18xer vvti, problems, problems
    By gstore in forum Engine & Drivetrain
    Last Post: 20th April 2012, 13:33
  3. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 2nd October 2011, 21:20
  4. HVAC Issues
    By Exclusive BV in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2010, 21:19
  5. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
