Thread: Is this a vectra c travel assistant??
    Regular Member sri andy's Avatar
    Apr 2009
    Lancs/Manchester
    Default Is this a vectra c travel assistant??
    as per title, is this for the vectra c ?
    Leicester
    Not a proper Vauxhall travel assist. It's an aftermarket version.
    The Vectra Travel Assist is identical to the Signum unit but it uses a difference base. Unfortunatly the base can't be bought as a seperate item.
    Apr 2009
    Lancs/Manchester
    Quote Originally Posted by Maverick View Post
    so would this fit my vec hatch or is there a base fixing missing? and if it does where abouts will it sit in the car?
    Mar 2007
    North East
    Doubt it, as would think there is a bracket missing.
    The Signum has a bracket which fits over the centre rear seat and connects to a socket on the floor to provide power. The TA then clips onto the mount. Would assume the Vectra is the same setup with a different bracket.
    Leicester
    Quote Originally Posted by sri andy View Post
    They sit on the middle seat, but the one in your picture, I have no idea as I have not seen one like that before.
    Leicester
    Quote Originally Posted by rockh View Post
    The proper VX travel assist for Vectra locates on the floor in the same way but it has a bracket that is fixed behind the centre rear seat and then the base goes through and attaches.
    Regular Member bigbnlr's Avatar
    Belfast
    This would be all over the place unless you put it's seatbelt on mate
    Regular Member Lump's Avatar
    coventry
    its for a zafria/meriva ive got one in the garage
    Glasgow
    Yep , Its for the Meriva
    Regular Member Jezzy's Avatar
    S.E
    That picture's from pistonheads isn't it? And isn't it just a box, rather than a cooler?
  1. vectra travel assistant
    By painter2166 in forum Vectra C / Signum Car Chat
    Last Post: 18th June 2011, 21:36
  2. vectra travel assistant
    By rorycarz in forum Parts for sale
    Last Post: 3rd April 2009, 21:00
