Thread: Shoddy Manifold & EGR Job by Vx
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Default Shoddy Manifold & EGR Job by Vx
    My car went in last week for a new Inlet manifold & EGR, it was in for over 24 hrs & I got it back just as the garage was closing for New Year. Driving home I found the drivers washer jet wasn't working so popped the hood when I got home & found it had been shoved down flush with the surround, I guess it was leant on, no prob Ė sorted, but looking at the engine the plastic cover didnít look right & on inspection I found it was only located on 3 corners, so I took it off. I then found that the injector loom had been routed over the fuel pipes, this looks wrong to me although I canít find any photos but it's obviously the reason the cover wouldn't go on properly Ė Iíve also found the wiring connector on the end of the fuel rail is broken & a number of wires & pipes have not been put back correctly/securely & are floating around loose Ė Iím not a happy bunny
    Mar 2007
    Southport
    Photos for above
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    you right m8 wiring should go under vac pipes looks like its been rushed what else is missing or broken?
    Mar 2007
    Southport
    Quote Originally Posted by paul wingnut View Post
    Most of the wires & pipes that had clips to hold them in place have been left loose with some of the fastenings broken & others ignored. I'm now trying to work out if they've replaced the Electric Drive Module - I can see it but can't tell whether it's new or old
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    Get back around there mate ASAP, leave as much as it is as possible. I would also contact VX UK direct and send them the photos and the name of the dealer.
    Glasgow
    Seems you have been the victim of a rush job, i thought it was only me things like this happened to. As above take pics and phone VX customer care and take the car back tell them to resolve there dodgy work.
    Mar 2007
    Southport
    I'm not going to use the car till Monday when I'll be sat on the their doorstep at 8.30 waiting to see the service manager!!
  1. Shoddy workmanship
    Last Post: 21st March 2010, 11:23
  2. Shoddy
    By bigmac in forum Vectra C / Signum Car Chat
    Last Post: 10th December 2008, 20:53
  3. Tips for dealing with shoddy service from stealers
    By PeterVV in forum Vectra C / Signum Car Chat
    Last Post: 28th November 2008, 20:35
  4. 2.4 manifold
    By lizard in forum Petrol Engine related
    Last Post: 15th November 2008, 22:00
  5. shoddy windscreen?
    By Adamdavi3s in forum Bodywork & Interior
    Last Post: 11th July 2008, 13:32
