Thread: U2116 Fault code
    New Member Oski's Avatar
    Poland
    Unhappy U2116 Fault code
    I got a problem with mentioned above fault code. Everytime I read fault codes with opcom that error comes up in CIM and Air bag sections - CAN bus no communication with IPC (instrument) even if it was cleared 1000s times before. Beside it, several times I got random errors P1614-50, U2107-70, U1423-72. Car runs smoothly, but am getting worried about a CIM. Can it be dying CIM? Need to mention... a sometime ago I resetted the CIM, programmed it as well as immo with transp keys and I had peace of mind for a while. Any ideas mates? Thanks in advance. Any help would be appreciated.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Don't worry. OP-COM reads 1000s of random fault codes on my car too.
    Regular Member wotsthestory's Avatar
    Jun 2007
    Carshalton
    Engine : 3.0 CDTI
    Mileage : 103000
    Think I had very similar errors when I reset my CIM (so perhaps it's related), I wondered if it was part of the section where you enable CIM&ECM. As it's saying it can't connect to something via CAN bus. I was going to have a look when it's warmer.
    But my car is 100% aside from this, so just ignore for now.
    Poland
    Quote Originally Posted by Celes View Post
    So it seems opcom generates noises to canbus itself.
    Quote Originally Posted by wotsthestory View Post
    Yes, that was the part - "CIM & ECM Present" in immobiliser section. I resetted ECU and CIM, because I thought it'd help. It helped - for a while. These errors come up again and again. I'll leave it as it is and see what's gonna happen.
  1. Fault Code help
    By MiniVauxhall in forum Engine & Drivetrain
    Last Post: 17th May 2012, 10:04
  2. fault code on vec c 1.8 sri please help
    By gavs-sri in forum Engine & Drivetrain
    Last Post: 10th April 2012, 21:52
  3. Fault code
    By bellsjoe in forum Engine & Drivetrain
    Last Post: 23rd May 2010, 22:24
  4. Help with fault code,
    By robwilson69 in forum Suspension, Wheels & Brakes
    Last Post: 13th December 2009, 21:57
  5. Fault Code
    By fattony in forum Engine & Drivetrain
    Last Post: 6th April 2009, 22:24
u2116
u2116 vectraGM DTC U2116-00GM U2116u2116 codeOpel DTC U2116-00u2116-00 opelfault code u2116Opel U2116-000maruti dtc u2116Opel U2116OPEL U2116-CDu2116 opelu2116 vectra cVauxhall U2116Opel DTC U2116-06u2116#spf=1maruti suzuki dzire trouble code u2116u2116 opel vectra cu2116 dtc in vehicleu2116 opel signumvauxhall code u2116u2116vauxhallVauxhall DTC U2116-0fault code u2116 for swift
