Thread: Replacement Airbag Pre-Facelift
    Regular Member wotsthestory's Avatar
    Jun 2007
    Carshalton
    Engine : 3.0 CDTI
    Mileage : 103000
    Default Replacement Airbag Pre-Facelift
    More often than not my airbag light pops on when I press the horn. (the harder I press it the more likely it is to come on). The light will sometimes disappear almost straight away, or after the ignition has been switched on and off. I was looking just to replace the airbag as the horn sensor is built-in? But only if it was cheap enough!
    ebay Link
    Found the above, actually quite fancy the Holden one and cheap enough.
    Is an '03 two wire and is the horn wired separately or all part of the airbag itself?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Its all one unit although you could try checking the wires are right in at the back of it
    Jun 2007
    Carshalton
    Engine : 3.0 CDTI
    Mileage : 103000
    Yeah, I just thought if I had to pull it out and I could get one cheap enough I'd replace it. I can always sell it on if it's not faulty.
    They are a two wire on pre-facelift though? I never believe what someone on eBay writes .....
    What do you think of the Holden badged airbag though?
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Yeah they are two wire on the pre-face mate. Price is pretty cheap for an air bag though.
    I like the holden one but i'd really be interested in a blank one (to fit a new style griffin in.
    Sep 2009
    Stratford-upon-Avon
    Have you taken the airbag off of the steering wheel and checked the connectors on the back of airbag, these may have just come lose!
    Oct 2009
    rhyl
    will a face lift steering wheel fit a pre face car if you put the 6 buttons on the new steering wheel
    Jun 2007
    Carshalton
    Engine : 3.0 CDTI
    Mileage : 103000
    I think actually my woes are CIM related, got other acts of randomness going on. I've once had the Steering wheel with exclamation mark pop up. Whenever I read the codes there are always some relating to the CIM.
    I might look at swapping it next month.
    Sep 2009
    Stratford-upon-Avon
    I would get it checked via tech2 or someone with legitimate vaux/op-com and chek the CIM for fault codes
  1. Seat airbag plug replacement
    By Simon_Fuller in forum Vectra C / Signum Car Chat
    Last Post: 19th October 2012, 23:03
  2. Airbag replacement - NSF (front passenger airbag)
    By Caveman_nige in forum Bodywork & Interior
    Last Post: 19th February 2011, 21:12
