Results 1 to 10 of 14
Thread: Juddering @ 1500 rpm
    Regular Member big nath's Avatar
    Jan 2008
    Irthlingborough
    Default Juddering @ 1500 rpm
    Started juddering at around 1500rpm last week and the spanner light came on but would go away when you turn of then back on again, when driving on motorways at speed is all ok but when your in traffic at low speed car is coughing juddering, so booked into stealers and they called me and said EGR so they went ahead and fitted new one, picked car up later that night and on the way home it is still doing the same tryed to call them but no answer so will re-book in, any ideas what it could be
    Jan 2008
    Irthlingborough
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Sounds like the third Injector wiring loom, a known problem on the CDTi 150.
    Oct 2009
    Teesside
    http://www.vectra-c.com/forum/showthread.php?t=73584
    There you go sir, I assume you have the 150CDTI ;-)
    Oct 2009
    Teesside
    Costs you £12 if you do it yourself, REALLY easy mate!
    Jan 2008
    Irthlingborough
    Thanks for that will go to my local stealers on monday and order part will let you know if it solves the problem
    Would it be linked to the flywheel as this is getting louder not getting any clutch slipping ?
    Jan 2008
    Irthlingborough
    Fitted new plug to 3rd injector didn't make any differance so have booked back into stealers on friday.
    Not to bad when moving but if i park up and rev to 1500rpm and hold it there car starts to judder or missfire, see what they can sell me this time.
    Jan 2008
    Irthlingborough
    Eek
    Following on from this juddering back from staelers today and the say turbo intercooler is leeking and the turbo is showing signs of leeking and the cat is leeking on the front flex pipe total cost £1868....
    Would this make the car judder at low speed ????
    Jan 2008
    Irthlingborough
    Unhappy
    And on it goes went into a differant stealers today for a second option, Called me a said the EGR so told them had one fitted 2 weeks ago at differant stealers and they said they would look deeper into it.
    Called back 2 hours later and said the intercooler was leaking and this may have cloged up EGR but will clean it out £334 So said ok go ahead he said will be ready for you later today. Called me back at 5:30 and said they couldn't get it to run right and they couldn't reset the ECU. I can feel more money coming out of my walet..
    Jan 2008
    Irthlingborough
    Just picked up car and still it judders at 1500rpm, now they say it could be the new EGR so they are going to fit a new one and see if it makes any differance then after that they will look at sending the injectors away to bosch but there tec 2 is saying nothing wrong with the injectors. And they say that if it's the EGR then it's not covered on it's warranty even though it's only 2 weeks old becouse the intercooler has stuffed it...
    No spare cars so service manager lent me his car with the same engine Ha this is how they should run..
  1. HELP, noise at 1500 rpm
    By woodspsx1 in forum Engine & Drivetrain
    Last Post: 18th May 2012, 02:34
  2. quoted £1500 for this repair.
    By ryantcb in forum Vectra C / Signum Car Chat
    Last Post: 5th September 2011, 15:09
  3. hesitation between 1500-2000 rpm
    By doggydoctor in forum Engine & Drivetrain
    Last Post: 28th July 2011, 10:42
  4. £1500 bill for CDTI
    By ONEMINUTESILENCE in forum Engine & Drivetrain
    Last Post: 24th July 2011, 12:04
  5. 3.0 V6 hesitation 1500 rpm (solved)
    By yoladeuche in forum Vectra C / Signum Car Chat
    Last Post: 4th November 2010, 10:59
Insignia coughing at 1500 rpm
https:www.vectra-c.comforumshowthread.php98718-Juddering-1500-rpm
