Results 1 to 3 of 3
Thread: rear camber measure/ajust
    Oct 2009
    bunkeflostrand
    Default rear camber measure/ajust
    hey
    i have lowered my car with the H&R springs and after that made and 4 wheel ajust but is it possible to ajust the rear camber on the vectra vxr...?
    i couldent see were to do that if it is possible it is because that the rear camber measure is out off range and my rear tyre is getting out of shape because off that...
    thanks in advance
    Oct 2009
    bolton
    hi mate yes it is possible to adjust rear camber and you will need to depending on how low you go will affect camber when i changed to coilovers my vauxhall mechanic had to obtain be spoke settings from a specialist company before setting the car up at vauxhall its the only way to set the car up correctly, hope that helps
    Leicester
    I have copies of the settings for cast and camber from TIS for the Signum and there is quite a bit of information. You should be able to obtain this information from your dealer.
    It is always good practice to have a full geometry check done after lowering.
  1. rear camber
    By cliff75 in forum Suspension, Wheels & Brakes
    Last Post: 6th July 2012, 14:38
  2. rear camber
    By tditony in forum Suspension, Wheels & Brakes
    Last Post: 2nd June 2009, 18:37
  3. Rear camber
    By WHOOSH05 in forum Suspension, Wheels & Brakes
    Last Post: 23rd December 2008, 21:39
  4. Rear Camber
    By Daywalker in forum Suspension, Wheels & Brakes
    Last Post: 24th June 2008, 14:24
  5. SRi rear camber
    By wrightgj in forum Vectra C / Signum Car Chat
    Last Post: 25th August 2005, 19:14
