Thread: 1.9 cdti turns over but fails to start
    Jan 2010
    wallingford
    Unhappy 1.9 cdti turns over but fails to start
    Hi, i'm having a lousy new year, my Veccy 1.9 cdti 150's alternator failed on boxing day, had to be towed home..great.
    Changed the alternator and started car. It started but felt guttless and a bit rough, not wanting to rev (The "car/spanner" light was on). I left it about 10 seconds, on idle, when suddenly the revs slowly dropped and it died. Now the car will only turn over but won't start up. The "car/spanner" light stays on.
    Battery tested and charged... no change
    RAC called....scratched his head....no fault codes found
    Next stop is an expensive garage bill, hence post.
    Anybody had or heard of these symptoms?
    Happy new year
    Regular Member cerbrious's Avatar
    Apr 2008
    Wigan
    the car spanner light being on means there is a stored fault code somewhere the equipment the rac use is very limited and cannot access all units withing the car you will need to get her on either a tech2, op-com or vaux com
    there is a thread with names of members willing to help along with there locations i have the equip but im a 4 hour drive away from you someone more local should help you out
    Regular Member signum03's Avatar
    worthing
    could well be glow plugs bud? easy change on yours.
    Jan 2010
    wallingford
    Cheers guys
    The glow plug light comes on briefly and extinguishes as normal....could it still be glow plugs?
    I'm going to try the free code check as described on another thread, but don't hold out much hope as it doesn't seem to work on cdti's.
    Cars dead, so getting it to a code reader means: garage....means: start of the bill!!
    Apr 2008
    Wigan
    read this thread pick a menber near you and send them a private message
    http://www.vectra-c.com/forum/showthread.php?t=96936
    Jan 2010
    wallingford
    Took it to the garage, an independant, he found a code refering to an out of alignment with cams and fly wheel. Basically, the timing had gone out. How? i've no idea. It wil now start and idle, but there appears to be no compression as it wont rev up.
    This points to valves and god knows what else damaged. The bill? How does around £1500 to £2500 sound?
    I've decided to take it off and do it myself, I only hope vauxhall don't have any surprises for me.
    This is definitly the last Vauxhall i will ever buy and probably the last car over £3000 as i'll need all my spare cash for repairs either way!
    Can't even set fire to it, as my MOT's expired!!!!
    My advise to anyone considering buying Vauxhall is to search the forums as hard as you can, because the information is out there folks, you just have to look.
    Thanks for all the help at Vectra-c.com, much appreciated support.
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    THe belt may have 'jumped' a tooth.
    Insignia VX-Line Nav CDTI 170.
    New Member JouniBoy's Avatar
    Jan 2010
    Finland/Turku
    I am just wondering is 120 HP version 8 valve construction,in that case maybe no damages only new belt is needed?
    Jan 2010
    wallingford
    Unfortunatly no. Its the 150 bhp 16v version. Yes, the jumped tooth idea sounds about right, the only question now is, what caused it to jump?
    I just hope i don't change the head and it does it again straight away.
    I'll change the cam belt, waterpump, any damaged stems/guides and hope for the best.
    I'll keep the forum updated, might help someone else in the future.
    First step, compression check to see which cylinders are knackered.
  1. Vectra turns over but will not start
    By TI7ANIC in forum Engine & Drivetrain
    Last Post: 24th August 2011, 16:32
  2. HELP! Car wont start, Engine turns over.
    By CDTI120SXI in forum Troubleshooting
    Last Post: 23rd July 2011, 13:57
  3. 1.9 120 cdti turns but won't start
    By weatherforcast in forum Engine & Drivetrain
    Last Post: 3rd March 2009, 14:25
  4. 2003 2.0dti 8v fails to Start
    By Neil.b in forum Engine & Drivetrain
    Last Post: 6th January 2009, 21:02
  5. 3.0 CDTI fails to start
    By Dominic Brown in forum Engine & Drivetrain
    Last Post: 4th September 2008, 22:11
zafira cdti turns over but wont start
my vauxhall 1.9 cdti turns over wont start
vectra 1.9 d turns over
engine turns over but wont start vauxhall vectra
my vectra turns over but wont start
2008 vauxhall vectra 1.9 cdti 150 wont start site:www.vectra-c.com
vauxhall vectra 1.9 cdti turning over but not starting
1.9 cdti firing but wont start
vauxhall vectra diesrl 1.9 8v car wont start
engine cranks but car wont start zafira b 1.9 cdti
