Thread: slow starting 1800
    cardiff
    Default slow starting 1800
    My 1.8 lpg vectra seems to take ages to start from cold. its starting on petrol so its not a gas issue, takes about 15 seconds of cranking before it fires. when its warm it fires up straightt away, havent long had the car so presume it may have always done it. any ideas? car runs fine after start on petrol and gas, battery is charged and has plenty of life. car has less than 50k and is 2005 model. it did throw up a couple of fault codes the other day but have since been cleared and not reappeared. codes were 302 and 100 (cylinder 2 misfire and maf or vaf circuit malfunction)
    any ideas gratefully recieved!
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    You keep it well serviced?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Plugs, leads and coil packs would be my starting point
    cardiff
    was serviced in july at 48k by a vauxhall dealer its only done a few hundred miles since then as was sat on the dealers forecourt since august.
    Jan 2008
    Dundee
    as john says leads plugs and coil packs would be a good starting point
    cardiff
    may have to try plugs and the pack, i had a feeling the coil pack maybe a bit ropey, i priced up a new one from vx at just over a hundred quid, ive seen aftermarket ones on ebay for about half that...not sure how long they will last though! have had some issues with cheap ones that ive used before. maybe best to put a original one on there.
    thanks for the ideas
    Jan 2008
    Dundee
    yeah i would put genuine on mate
  1. Slow to pull away - dangerously slow to pull away (150cdti auto)
    By the1theycallthe1 in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2012, 21:10
  2. stutter between 1800-2200
    By DeJohnny in forum Engine & Drivetrain
    Last Post: 31st July 2011, 12:47
  3. A stutter at about 1800 RPM
    By Ginge7289 in forum Engine & Drivetrain
    Last Post: 2nd May 2011, 09:03
  4. 2004 1800 sxi 66k fsh
    By j1 wyx in forum Cars for sale
    Last Post: 3rd January 2009, 17:29
  5. 1800 LS- what can i do
    By armoured farmer in forum Petrol Engine related
    Last Post: 7th October 2005, 21:04
vectra c slow starting 1.8 petrol
