Thread: 1.9CDTI Oil 'Quality' Sensor
    Wales
    Question 1.9CDTI Oil 'Quality' Sensor
    I think I am correct in saying that the 1.9CDTI has an oil 'quality' sensor. (It is used if you are on the 20k 'Ecoflex' service schedule).
    Does anyone know if it is possible to 'read' the sensor and so gauge the quality of the oil? If this can be done in-car somehow then great, otherwise does tech2/opcom or do any of the cheap code readers allow this?
    Nov 2007
    lancashire
    dont think it has a oil quailty, more a program built into the ecu that works out how hard you have accelerated, how many cold starts, motorway driving ect and then says you need a service. thats why you have to reset it manualy after a service.
    Melbourne, Australia
    There's no oil quality sensor. The engine computer predicts degradation of the oil by considering operating conditions of the engine (oil temperature, engine revs, etc). That's why you have to use specific oil if you use oil life monitoring, to ensure that these calculations are correct.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    It is a 'virtual sensor', not a 'real' sensor, as above
    Not just the 1.9 CDTI, but will apply to any and all engines between 2002 and 2005 with ECO Flex option
    Equally, the ECO Flex can be switched off by TEC2, pretty much proving that it is the way in which the EMS works out and saves the data between service resets
    However there must be some form of oil quality calculation
    Mine is very accurate until there is about 10K miles left to next service, showing 20K miles
    It then drops quite dramatically, especially in the final 5K miles
    I suspect it uses the rate at which the oil flows and the oil retains heat
    Having just had mine serviced it takes a LONG time to heat up
    However before the service it was heating up very quickly (by comparison)
    That would be indicitive of all the contaminants in the oil, resulting in reduced lubrication and heat disappation
    Leicester
    You can have it read via tech 2. I had my Signum read before it was serviced at 40k (2007 57 plate) and it was down to 15%.
  1. Air Quality Sensor
    By v6boy in forum Vectra C / Signum Car Chat
    Last Post: 8th October 2015, 16:44
  2. Coolant Sensor Connector - 1.9CDTI
    By howarthcd in forum Electrical & ICE (including SatNav)
    Last Post: 14th June 2011, 21:30
  3. N/S/F Abs Sensor 56 plate 1.9cdti
    By Diesel Dude in forum Suspension, Wheels & Brakes
    Last Post: 15th January 2011, 10:57
  4. swirl and boost sensor 1.9cdti 150
    By mark230678 in forum Engine & Drivetrain
    Last Post: 25th May 2009, 20:09
  5. Interior Air Quality Sensor
    By denzo in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2005, 19:15
vauxhall insignia oil quality sensor
