Thread: Door strap replacement
    swansea
    Default Door strap replacement
    Doing this on the weekend, any tips on removing the doorcard, don't want to break anything. Happy new year to you all.
    WGAF#5
    follow the how 2 "replace the door speakers" the prinpals the same and once you remove the speaker its easy access
    http://www.vectra-c.com/forum/showth...hlight=speaker
    Regular Member Stuarty's Avatar
    Aberdeenshire
    Did mine a while back was an arse of a job to get the door card off i suggest you get some new pop clips or whatever theyre called as mine were very brittle and four of them shatterd taking off the door card!
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Hi..dya remember the part numbers for the straps and price?..
    swansea
    Part no. 24413389 drivers side. £17 inc vat
    swansea
    Can anyone give me confirmation on the above part no. Tried to fit the part I was given and they are slightly different. The original has welded bolts and is secured by nuts, and the new part has threaded holes for bolts.
  1. clunking door strap
    By redross555 in forum Vectra C / Signum Car Chat
    Last Post: 19th September 2011, 12:52
  2. drivers door check strap busted
    By valvelift in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2011, 12:12
  3. New door strap fitted.
    By badback in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2011, 20:54
  4. Door Check Strap!
    By @ndy-e in forum Bodywork & Interior
    Last Post: 5th October 2009, 15:01
  5. door strap torque bolt
    By grumpano in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2009, 17:40
how to replace vauxhall vectra C check strap
how to replace a door strap on a opel vectra
How to relpace vauxhall vectra check strap
replace door strap vauxhall vectra life
vauxhall check strap replace
how to replace vauxhall vectra C DOOR check strap
change vauxhall vectra c check strap
check strap vectra c replace
