Thread: Vacuum Pipes on Diesel engines
    Northampton
    Default Vacuum Pipes on Diesel engines
    wonder if anyone has had or having the same problem, i keep havin problems with the vacuum pumps for the turbo keep going or having a hole in it.
    which does not let me go above 2500 revs and going into limp mode!
    is this a common fault? my car has done 80k now and i have replaced two pipes replaced but i dont know which one it is now!
    took it down the garage and they said they'll fill the system with disco smoke and find the pump which is letting the pressure out!
    Regular Member bigbnlr's Avatar
    Belfast
    Yep mate happened to mine a few times, luck enough my mate used to work for vauxhall and sorted it im 2 mins. You just got to look at each end of the pipes first as they split very easly tbh.
    Northampton
    oh rite, i dont know how many vacuum pipes there r. they really are annoying. as one pipe can cost abit! i shall have a look!
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Are you sure you mean vacuum pipes and not boost pipes? I know that the vacuum pipes sometimes go but not that often
  1. Vacuum Pipes. 1.9 120. 2004 vectra c
    By carling in forum Engine & Drivetrain
    Last Post: 30th January 2013, 15:22
  2. vacuum pipes from pump
    By james walker in forum Vectra C / Signum Car Chat
    Last Post: 15th July 2011, 22:00
  3. P 0100 on vectra dti is back but my vacuum pipes intact!
    By yogishniz in forum Vectra C / Signum Troubleshooting
    Last Post: 12th July 2011, 10:37
  4. Do vacuum/boost pipes have to be a certain length
    By tommytonguedj in forum Engine & Drivetrain
    Last Post: 27th May 2011, 17:05
  5. Another post about Vacuum Pipes!
    By lostdog in forum Diesel Engine related
    Last Post: 30th March 2011, 11:35
